Throttle body spacers
3 posts • Page 1 of 1
AS above guys,
Basically I'm wondering whether these are any good and if its worth getting one.
From what I understand, it sits between (in my case) the intake manifold and throttle body and what it does is it increases chamber volume and aids air flow and also creates a spiral effect to the incoming air. This apparently has worked well on some setups gaining as much as 18bhp I read somewhere and improves low and mid range.
Is this true?
Furthermore, would I benefit from using it on a simple throtte body/inlet manifold standard setup?
Is this true?
Dreaming of my first FRST....
- paniK
Re: Throttle body spacers
Dunno, but asking in one of the technical forums might get you an answer
Nothing to see here...
- andymac
- Elite Pie Master
oops.
will do
could a mod move this or shall i start another thread?
EDIT: thanks mods
will do
EDIT: thanks mods
- paniK
