throttle body
17 posts • Page 1 of 1
throttle body
Strange question to ask i think it will work,
1.8 gti escort
if i put a 2.0l throttle body on my car and put the 1.8 TPS on it
the only difference i can see is the size on the throttle plate its bigger on the 2.0l
which means more intake thus more BHP anyone disagree or can it be done easily??
cheers Darrell
1.8 gti escort
cheers Darrell
RS1800 Done and dusted
- Dwayneology
- Your car: Yamaha YZF R1, RS1800
Re: throttle body
Common mod to the 1.8 mate
yes the 2.0 throttle body will go on (from a mk1/mk2 mondeo)
Tps are the same on both, so no need to change it over. Might need to put the escort throttle cable bracket on the 2.0 one though, as the 2.0 barcket prob wont fit your cable
- SamT
- Dwayneology
Re: throttle body
does it make more bhp much?
RS1800 - Dangermouse is back!!!!! VOTE DANGERMOUSE ft-calendar-voting-thread-get-voting-vt176334/
- dangermouse
Re: throttle body
It may gain 1 or 2 but what you gain in bhp you lose in torque.
- Tweek
- Your car: VW Golf GTD
Re: throttle body
so really its not worth the money unless your going for the 2litre engine swap
- dangermouse
Re: throttle body
Well, the different sized throttle bodies on the 2 litre have the same effect. use a 1.6 and you get good torque but lower bhp, 2.0 tb gives you higher bhp but lower torque. Needless to say I've stuck with the RS1800 tb lol.
- Tweek
Re: throttle body
Tweek :Well, the different sized throttle bodies on the 2 litre have the same effect. use a 1.6 and you get good torque but lower bhp, 2.0 tb gives you higher bhp but lower torque. Needless to say I've stuck with the RS1800 tb lol.
pretty sure the rs1800 throttle body is the same size as the 2.0 anyway lol
- SamT
Re: throttle body
lol catch 22, i just stick with what i got then lol
- dangermouse
Re: throttle body
been told that with the 2.0l cams and throttle body its the 130 bhp spec
due to the fact there is no egr on the gti and is standard at 115bhp
is this a load of crap
or for 130 am i looking at a 130bhp ecu
- Dwayneology
Re: throttle body
ideally yeh you would use the 130 spec ecu aswell, but then you will have all the issues with pats etc... when fitting it.
What i had on my old escort (115 spec) was the 2.0 cams throttle body and a collins powerchip and made 127 on the rolllers. Some make more power, depends on how good your engine is really. But i recon the powerchip done naff all really
- SamT
Re: throttle body
my other half has a gti with piper cams, 2ltr TB,pipercross cone filter,superchip and a magnex system and it makes 143bhp on dynodynamics rolling road and 135bhp without the cams at engine advantages. so you can get good power for little money.
- matty872
Re: throttle body
i just put a second hand engine in it the old one blew up cos the last owner last a fudgekin dick
it only had 60,000 on the clock and i put a new head gasket etc on it
i'm putting an ashley performance manifold on it next month good or bad???
- Dwayneology
Re: throttle body
ashley tend to rot quite fast though should give a little extra power.
- matty872
Re: throttle body
i had an ashley manifold on mine also, there alrite yeh, cheap an cheerfull, but as said, they are mild steel, so yeh rust can be an issue after time.....
but if your after a little more extra, id work on the inlet side, im not talking about poxy induction kits, more along the lines of the manifold, cuz the zetec inlets are really s**t. if you dnt want to go into throttle bodies you can adapt a rover inlet to fit, few modifications need doing, but it'll be alot better than the s**t gti plastic inlet run that with a sealed cone or standard airbox with a decent panel filter, with the least amount of bends in the induction piping as you can and you'll have a good intake system on the car
- SamT
Re: throttle body
i've actaully got a rover inlet manifold spare i was going to use it to make a zetec turbo engine with my mate
are they that much better then what i'm finding with my gti is 1st 2nd 3rd 4th the torque and acclerertion is great i mean it'll do 115 mph in fourth gear but 5th really struggles they is no go in it
i feel i need more power in that gear i know its a crusing gear but it struggles getting over 125mph and at that speed its only doing 4500rpm it just doesn't want to accelerate any faster than what it does i run out of road
so will cams, throttle body, manifold and a rover inlet give me that extra in 5th cos really thats all i want i'd be happy with that
- Dwayneology
Re: throttle body
Dwayneology :i've actaully got a rover inlet manifold spare i was going to use it to make a zetec turbo engine with my mate
well in my old one, i could get 120 in 4th, and over 130 in 5th no problem, would keep pulling
so yeh, i recon it would
- SamT
