To dump.............or not to dump !!
8 posts • Page 1 of 1
Right, I have a frst on 83k with increased boost via bleed valve. It also has a superchip, mongoose exhaust, k & N, dump valve and I want to change the sound. I like the fa fa fa sound you get when having a turboed car without a dumpvalve and I am considering taking it off and putting a blanking plate in instead. Is this wise considering I have increased boost ??
I think the boost is around 0.9 to 1 bar!!
Also if I do remove the dump valve do I need to plug the small outlet on the inlet housing ???
Cheers all !!
Cheers all !!
- Gozza_RS
dump the dump
natural sound of a turbo on gearchange is fookin sweet as
- 285Andy
- Your car: fiesta rs turbo
Nooooooooooooo I have a dump valve at the mo, (baileys dont ya know ). I wanna change the sound tho as everyone has dump valves !!
I am just wondering if it will damage the turbine blades due to the increased boost ??
- Gozza_RS
no it won`t damage the turbo the dv on a fiesta has no use apart from the sound they make i`ve got a biltz blow off valve that i had on my fiesta but i wanted that lovvvely wastegate chatter that you get with abig cone filter plus no vented air
- turboboss
If you are running 1bar (like me) i would recommend you DO use a D/V. There is a lot of back pressure going back through the turbo, better to get rid of it than have the fluttering sound.
Use a twin piston type d/v this way you will keep any nasties out of your engine........i recommend a Collins twin piston d/v
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
