Toad AI606 Boot Release
13 posts • Page 1 of 1
Can someone with knowledge on these things please help me out? I've wired it up using a 40A SPNO relay (following the guide on fiestaguides) and according to my alarm manual it creates a 1 second negative pulse to pop the boot, but, it does nothing The button in the car still works fine though.
Gone through the software too and it's definitely set to do that using the blue/black (#6) wire:
- Tweek
- Your car: VW Golf GTD
- dontpannic
Re: Toad AI606 Boot Release
What nail polish do you use?
- fiend
fiend :What nail polish do you use?
- Tweek
..I dunno I posted it at 4.30am.
- fiend
What the hell, that random
- M1K3Y_B
Car: 1996 Ford Fiesta Classic
have you managed to get this working yet? i got the same problem with mine button works fine but i cant get it working off the alarm
The stink of excellence in a world gone funlumps up
- CossieDan
Car: 1995 Ford Fiesta Ghia 16v
Nope, haven't touched it since
- Tweek
I fudgekin did it! im so proud of myself
setup is
pin 87 - boot solonoid
pin 85 - Alarm (negative pulse)
pin 30 - +12v
Pin 86 - +12v
hold down button 3 on the remote for 3 seconds and pop goes the boot
setup is
pin 30 - +12v
Pin 86 - +12v
- CossieDan
CossieDan :I fouquette did it! im so proud of myself
setup is
pin 30 - +12v
Pin 86 - +12v
Thats the correct setup mate. Mine worked first time
- dontpannic
Looks like I've got 85 and 86 the wrong way around then
Will go try that.
Will go try that.
- Tweek
yea thats what i think i had wrong as well, and i wasnt holding the button down long enough
- CossieDan
just tried that, still doesn't work
I've got the 2 +12v wires going to the live side of the boot switch too. Used a multimeter to make sure they're definitely the right way around
- Tweek
