track rod ends
5 posts • Page 1 of 1
track rod ends
not a hard job are they just undo the large nut at end then nut at the bottom and remove them and twist off the threads
but do you need a split pin to go back in after , just wondering as sometimes its an mot requirement and possibly safety issue too?
- xr2irhys
Car: 1996 Ford Fiesta Classic
Re: track rod ends
if it had split pins to start with then you must refit them unless the new trackrod ends came with nylock nuts which replace the castle nut and split pins doesnt matter if it's an mot failier or not loosing your steering at speed would not be good and for the sake of a 1p split pin
- allinking
Re: track rod ends
allinking :if it had split pins to start with then you must refit them unless the new trackrod ends came with nylock nuts which replace the castle nut and split pins doesnt matter if it's an mot failier or not loosing your steering at speed would not be good and for the sake of a 1p split pin
ok cheers chap ill have a look , so if it has the lock nuts with the blue threads it isnt required to use a split pin?
- xr2irhys
Re: track rod ends
xr2irhys :allinking :if it had split pins to start with then you must refit them unless the new trackrod ends came with nylock nuts which replace the castle nut and split pins doesnt matter if it's an mot failier or not loosing your steering at speed would not be good and for the sake of a 1p split pin
No the nylon in the nut stops it coming undone some people don't trust them and still fit the castle nut with split pin but its personal choice the only thing i will say about the nylock nuts is if you remove it at anypoint then you must change it thus why the castle nut is easier as your only changing the split pin each time.
- allinking
Re: track rod ends
im with ya.......... cheers for that
- xr2irhys
