Tracking on my Turbo
13 posts • Page 1 of 1
Havin some problems setting up the tracking on my turbo to get it to handle and feel right, what toe in or toe out does anyone use. Its not for track use more for high speed use, any comments appreciated
thanks
thanks
- FRST5090
first off, make sure you have the same ball joints both sides, sounds bent, but the frst has its own ball joints to other fiestas, there 10mm loner and 10mm set back and the tracking is
toe setting
allowable tolerance before resetting is required -4.0mm(toe out) to 0mm
setting adjustment, if required -2.0mm (toe out) +/- 1.0mm
nominal tolerance range
castor -1.45 0.45 to -1.15
camber -1.15 -2.30 to 0
that info any good to ya?
toe setting
yeah it will throw the tracking out etc, you can use the different arms and ball joints as long as both sides are the same, sounds stupid i know but ive seen it done, even done it my self once a long time ago, then thought wtf is going on there
sounds like the uj is worn or the rack is focked.
wiggle the steering wheel side to side to side without making wheels turn and see how much play you got, if you got a bit, get someone to look at the uj while you do it to see how much it moves
