TTF Si 2.0 - WOAH! An update! - 29/08/2014
Re: TTF Si - Temporarily coming off the road- Engine swap- 22/12
Postby - Danny Boy - on Fri Dec 23, 2011 9:38 pm
Luckily, I have sourced a HO inlet with rs1800 TB, 2 litre maf and 2 litre ecu too, so that should be here in the new year :) So all being well, should run rather smoothly!
- Danny Boy -
Your car: Fiesta Si 2.0
Postby jonyb4 on Sat Dec 24, 2011 1:39 am
thats lucky then its a right ball ache swapping manifolds over, lot of dead arms reaching from under the car :P
Postby Ratspeed on Sat Dec 24, 2011 6:45 pm
jonyb4 :thats lucky then its a right ball ache swapping manifolds over, lot of dead arms reaching from under the car :P
Like when you have to reach around to grab a handfull of 'conquering device'............
Ratspeed
Postby jonyb4 on Sat Dec 24, 2011 6:46 pm
Exactly!! such an awkward situation to land yourself in... as you know ;)
Re: TTF Si - small update - engine painted + new bits - 11/01/12
Postby - Danny Boy - on Wed Jan 11, 2012 9:30 pm
Sup guys, small update on the engine.
Over the last few days I've decided to crack on with the engine, making it look fresh and new ready for the swap and renewing some bits on it.
So before it got stripped down, it looked like this if you cant remember: ttf-si-small-update-engine-painted-new-bits-11-01-12-vt182547-210/#p1885585
There are still a few bits to come; HO/RS1800 inlet, 2.0 throttle body, 2.0 maf and 2.0 ecu. These are being sent out next week thanks to Funkynut on FSI. Once they are here, I will clean them up and spray them silver. Bits to be sprayed are; inlet, throttle body, injector rail, maf, rocker cover and a few other bits. Going to do it as one bulk lot to make the most of the spray cans.
The other day I got this lot:
- CVH Bosch oil filter
- Circoli water pump
- Pagid ST150 brake pads
- Continental contitech cambelt kit
- Continental contitech drive belt
- Valeo clutch kit
Today I picked up a few gaskets and spark plugs.
Then cracked on.
Engine stripped down
Sump wire brushed, block and head cleaned of any grease
Block painted black
Head and sump painted silver, and dipstick tube
Exhaust manifold painted
Cam pulleys painted silver
Cambelt off
Water pump off
New water pump vs old
New water pump fitted
New cambelt kit fitted
New oil filter, engine filled with new oil too
Back of engine painted
Going back together
Result of engine painted
Crankcase breather painted and fitted
Exhaust manifold fitted
I will update this again when the other bits turn up and are painted :)
Engine should be goin in next week at some point :thumbsup:
- Danny Boy -
Postby Excursion on Wed Jan 11, 2012 9:57 pm
Looking good 8)
Postby FRSJON on Wed Jan 11, 2012 10:30 pm
looks loads better danny,nice one :)
FRSJON
Postby jonyb4 on Wed Jan 11, 2012 10:39 pm
tenny tinny oil filter :)
the 1.6/1.8 one is double that size :o
is there a drawback to that? seems like it would need replacing twice as often, even though its used plenty by many people
anyway good job all looking nice and fresh, an extra 40bhp coming soon :D
Postby - Danny Boy - on Wed Jan 11, 2012 10:56 pm
Cheers guys! :)
jonyb4 :tenny tinny oil filter :)
No real drawbacks as such, the main advantage of using the CVH filter is that you dont need to change the oil pump to the fiesta one, the fiesta one is shorter but the filter is longer. It can be left on and replaced at normal service intervals as far as I'm aware. I always change the oil often anyway, so it will make no real difference to me :)
- Danny Boy -
Postby Dave5300 on Wed Jan 11, 2012 11:08 pm
looking good danny :)
Dave5300
Postby jayrs on Thu Jan 12, 2012 12:10 am
looking good mate.
your gunna know about it when that paint starts cooking on that manifold :oooh:
Postby jonyb4 on Thu Jan 12, 2012 2:42 am
ha will probs burn off in the first few hours :( smelly
Postby - Danny Boy - on Thu Jan 12, 2012 10:29 am
Yeah more than likely Jay lol. I don't mind if it burns off though if I'm honest, I just wanted it to look nice while it was all out. If I didn't do it then I would have been annoyed with myself knowing it's not done :lol:
- Danny Boy -
Postby jayrs on Thu Jan 12, 2012 11:39 am
i kow what ya mean mate, its the sense of satisfaction seeing it all new looking that matters :)
Re: TTF Si - small update - 21/01/12
Postby - Danny Boy - on Sat Jan 21, 2012 5:57 pm
Just a small update on the car/engine.
Got myself a RS1800/HO inlet manifold and throttle body, 2.0 maf and 2.0 DEWY ecu from a member on fsi which is awesome, those was the last bits I needed too.
So as you can imagine, I stripped them bits down, cleaned them up and sprayed them along with a spare rocker cover I had too.
I also bought a few new gaskets and a new splitter for the car because mine got ripped off being so damn close to the floor :lol:
Aaaaaaaaaaaand also, I got this of ebay for £5 :lol: I needed a workbench in the garage, so what better than a computer desk! does the job nicely, can work on parts in comfort now :lol:
- Danny Boy -
Postby Minstral on Sat Jan 21, 2012 6:30 pm
love the garage setup danny.
perhaps see if you can get the split of the splitter in the center of the car this time. way i did it was strongest and easiest at the time as it kept the bit that sloted into the other side as you know
Minstral
Your car: *
Postby - Danny Boy - on Sat Jan 21, 2012 6:40 pm
Yeah I will do :) I got this one brand new off ebay for £15 posted, cheaper than some of the 2nd hand ones on there!
- Danny Boy -
Postby Ratspeed on Sat Jan 21, 2012 6:58 pm
Thats cheap mate, my mk1 GTI splitter was only 15 too :Q
Whens the engine off in then?
Ratspeed
Postby - Danny Boy - on Sat Jan 21, 2012 7:23 pm
Engine should be going in tomorrow :) actually cant wait! I'm going to give the engine bay a really good once over while the old engine is out too :)
- Danny Boy -
Postby jonyb4 on Sat Jan 21, 2012 8:45 pm
good stuff, i regret not doing mine while the lump was out :(
Postby jonboisescort on Sat Jan 21, 2012 9:42 pm
looking good mate :D :D
jonboisescort
Car: 1994 Ford Fiesta
Postby - Danny Boy - on Sat Jan 21, 2012 9:48 pm
Cheers guys :)
I've just spent an hour in the garage putting together the inlet manifold and doing some other bits - will get pics of the manifold tomorrow.
Need to get some lights in there :lol: its hard when there is no electric down the garages though! :(
- Danny Boy -
Postby jonyb4 on Sat Jan 21, 2012 10:11 pm
f**k it candles!
get a leisure battery or something and wire up some 12v lamps :) in the corners of the garage
Postby - Danny Boy - on Sat Jan 21, 2012 10:43 pm
Cant be bothered spending s**t loads for some lights, i'll probably just end up getting some cheap LED lights of some sort for now, then look into something more at a later date if need be :)
- Danny Boy -
Postby jonyb4 on Sun Jan 22, 2012 12:18 am
halford button lights it is :D
Postby Ratspeed on Sun Jan 22, 2012 11:07 am
well its tomorrow. She running yet? :lol:
Ratspeed
Postby hb69 on Sun Jan 22, 2012 11:35 am
With the cvh oil filter you may still have to jack the engine up when you want to change the oil filter. The renault 5 filter comes off with no trouble
hb69
Your car: Fiesta 1.1 LX
Postby Excursion on Sun Jan 22, 2012 11:49 am
I like the desk, now you need a beer fridge :D
Postby - Danny Boy - on Sun Jan 22, 2012 8:38 pm
Ratspeed :well its tomorrow. She running yet? :lol:
Nah :( should be tomorrow though!
Got the old engine out today, started changing the bits over, had a visit from my mum and faffed around a little bit too. The new engine didn't go back in today though, I knew realistically on my own it was a 2 day job anyway.
So tomorrows job is to finish building up the new engine - literally just a few hoses to connect, the inlet manifold and thats it, gearbox and clutch are already on... then give the engine bay a quick once over and make it clean, then put the new engine in along with the new ECU and all should be good. Hopefully it will be done by tomorrow afternoon :) I will upload pics and maybe a vid tomorrow :)
hb69 :With the cvh oil filter you may still have to jack the engine up when you want to change the oil filter. The renault 5 filter comes off with no trouble
Cheers for the heads up! I'll look into a renault 5 filter if this one gives me any hassle!
Excursion :I like the desk, now you need a beer fridge :D
Yeah I sure do :lol:
- Danny Boy -
Postby Rhinopower on Sun Jan 22, 2012 8:41 pm
Be careful, running the renault 5 filter increases the oil pressure ;)
Rhinopower
Your car: Volvo FH330
Postby Excursion on Sun Jan 22, 2012 8:53 pm
Rhinopower :Be careful, running the renault 5 filter increases the oil pressure ;)
Yes people that's something to be aware of when swapping between sealed filters. Look inside the end of a new one and you'll see why.
Postby - Danny Boy - on Sun Jan 22, 2012 9:05 pm
Hmm maybe I will stay away from that then! I dont mind jacking up the engine a little bit to change the filter if it needs doing anyway, just means it will take an extra 10mins on top of the normal time to do it :)
- Danny Boy -
Re: TTF Si 2.0 - 2.0 litre engine conversion done - 23/01/12
Postby - Danny Boy - on Mon Jan 23, 2012 7:37 pm
So, the new engine is in, running, and perfect.
Totally fudgekin worth it!!!
Its still running the Si gearbox, but its all good. Will eventually get an escort one with an LSD I think though lol. Or just hunt for an LSD and put it in my spare escort gti box.
I'll basically let the pictures do the talking!
How it all started...
Old engine out
Lifting the car up to get the old engine out
End of day one I basically stipped the old engine down a fair bit then transfered all the bits onto the 2 litre engine.
Day 2 started as follows.
New engine built up, new clutch on there too, but didnt get a picture.
Going in, covered up of course lol
A while later, new rocker cover on ect ect, all plumed in, wired up. DONE!
FILTHY car on the floor.
Random one of me at the end of the day
Was it all worth it???
- Danny Boy -
Postby rsturbonutter on Mon Jan 23, 2012 8:27 pm
Good work there fella all on your lonesome :D :D
rsturbonutter
Your car: Fiesta RS turbo
Postby Dave5300 on Mon Jan 23, 2012 9:51 pm
looks good mate, good pull off her now id say :Q
Dave5300
