Tuning 1.6 si lump for track car project
16 posts • Page 1 of 1
Just bought an si to use as a track car. deciding what engine to have at the mo. DO you reckon its worth using the 1.6 engine with 130ps cams and an rs1800 throttle bodie. The only reason i ask is cause i have these parts to hand.
Or do you reckon the si head is to restrictive? should i put i 1.8 head onit will that actually fit??
- Sunil_FiestaRS_16V
The head should fit and would have the advantage of the bigger valves etc, deck the block while your there to increse the compression. I've been thinking of alternative tuning for my Si as everone seem to be doing the 2.0 conversion. If your going to use the RS1800 TB you might want to change the MAF sensor as the 1.6 MAF sensor is tiny. Once that is done, get it mapped using one of those MSD chips and it should have some decent figures.
HTH
HTH
- krsi
krsi :The head should fit and would have the advantage of the bigger valves etc, deck the block while your there to increse the compression. I've been thinking of alternative tuning for my Si as everone seem to be doing the 2.0 conversion. If your going to use the RS1800 TB you might want to change the MAF sensor as the 1.6 MAF sensor is tiny. Once that is done, get it mapped using one of those MSD chips and it should have some decent figures.
HTH
cool i wil try and doit then and see what happens. Im not gonna spend out on chip for it though as this is being done on a budget. My rd car is gonna have a live mapped msd chip though
Wicked, let me know it goes. One thing to consider, although i dont know how true it is, but the 1.8 and the 2.0 head may lower the compression. So decking the head or the block (not sure which people do) may be a good idea. Are you going to run a standard ECU or are you going to swap for the 1.8 or 2.0 item, just wondering.
- krsi
krsi :Wicked, let me know it goes. One thing to consider, although i dont know how true it is, but the 1.8 and the 2.0 head may lower the compression. So decking the head or the block (not sure which people do) may be a good idea. Are you going to run a standard ECU or are you going to swap for the 1.8 or 2.0 item, just wondering.
How can i find out if a 1.8 head will lower comp?? Also how can a find out how much decking is needed to be done to give a good high comp for my engine. Ive had my 2.0 decked but that was all done by raeline and im not sure how much they took off.
Not sure on what ecu yet bit of trial an error will be needed. There is still the option of ditching it all and going carbs aswell
Im not sure mate, maybe raceline will know about if it will need decking? Carbs would be fun although i think they a little bit more agro then there worth and that aint sticking to a budget is it
- krsi
krsi :Im not sure mate, maybe raceline will know about if it will need decking? Carbs would be fun although i think they a little bit more agro then there worth and that aint sticking to a budget is it
na it aint sticking to a budget but if i can get em second hand i might consider em. But ive also got a trust electrical inlet i was gonna use on my car so i might have a play at fitting that. I reckon with a decked block ,130ps cams, t.e inlet, 1.8 manifold. 1.8 head, 1.8 management it should have a bit of grunt especially as its gonna be totally stripped aswell.
krsi :Yeh, it sounds like it would be a quick little car. You kept the trust electrical manifold then, did you manage to figure it out? what throttle body would you use with it?
yea i know how its works its just gonna be a pain to fit. You have the cylinder that goes on the back of the head. Then you have pipe from this going to a plate . You fit your butterfly and throttle linkage part of your std throttle body to this plate then have another pipe to ur maff then to ur induction kit. Basically its a bit of a bodge and is pain to figure out where to put everything. Also there is no where for icsv to go so you need a remote one bodged in somewhere as well bypassing the butterfly.
if that makes sense lol
krsi :Can you use one of those little breather filters on a remote ISCV ? as it would save time by-passing the butterfly. Just an idea .
yea i could do that for the inlet side of it but it needs the outlet side going in after the butterfly . Cause from what i understand when the butterfly is closed it lets in air
- AdrianFRST
- Baby Battle Scratch
- Your car: ..? Pretty car..!
Car: 2010 Ford Focus RS
AdrianFRST :1.8 head won't fit sorry
Bore size is different.
It fit´s fine, but the combustion chambers are fifferent size. Here´s a link:
Story of a mk3 Fiesta
- Hartza
Hartza :AdrianFRST :1.8 head won't fit sorry
I've only skimmed through it, but I can't see anywhere on that page that suggests the 1600 block will accept the 1800 head.
Best knowledge to date says that the 1800 head will not seal properly to a 1600 bottom end. If you really want to check, compare the two headgaskets.
- Project
- fiftyoneCL
Project :Hartza :AdrianFRST :1.8 head won't fit sorry
Oops, I didn´t read the topic, or I didn´t understand it 1.6 Zetec head has smaller valves and different shape/size combustion chambers. But I have to compare gaskets at work...
- Hartza
Hartza :
Now I Have compared 1.6 and 1.8 zetec headgaskets and all the bolt holes and oil channels match. but oviously bore size is different and 1.6 cylinder holes are not round. And there are couple small holes that don´t line up... I have not seen a 1.6 head, but I assume the combustion chambers are different shape. It would be too much hassle to get the C/R right and find a proper gasket, pistons, ect...
Just get the 2.0 Zetec.
- Hartza
