Tuning 2.0
18 posts • Page 1 of 1
Tuning 2.0
Mondeo Series Two 2.0 Zetec...what are the best things to go for? NOt looking to spend an absolute fortune...just wondered what to do r.e. stuff like air filters, exhaust sytems (fancy a twin exit powerflow), chips etc....
- Danny 2i
- The White 2i Guy!
- Your car: N/A
as far as filters go i picked up a bit of a bargain from halfords of all places! there gettin rid of green cone filters for xr2i 1800 zetecs £30, half price. This may fit your engine, ive fitted one to my 1800 and it had a big difference and gave a nice roar, might be worth a look.
- stu1800
Well im still in the investigation stage for a 2 litre trying to weigh out my options with insurance being the main problem I reckon. I think theres not much difference between induction kits cos to be honest an engine will suck as much as it can but the filter will make it suck that little easier. For an exhaust i dunno but i expect a custom one will be needed. A few people on here have done the conversion so they would be best to ask. In fact the more I talk about a 2 litre the more I want it.
- moulder
Me too! Need to sell the 2i and get an Si before i can do that though!
What about other stuff? e.g. chips etc? Shoudl I look into stuff like this or do other things first?
Basically what other options do I have?!!!
- Danny 2i
- The White 2i Guy!
- Your car: N/A
Y r u getting rid of the 2i and getting a si, as now im worried cos iv got a 2i. I hope ur not doing it cs the 2.0 will not fit in a 2i or something harsh likme that, cos now me plans are ruined. The bloke with the mk1 fezzie has got throttle bodies on his and he got 180 bhp. Then the usual stuff like head, cams, lighten and balance everything, high compression pistons, strengthen the internals, the list is endless and all depends on your bank balance cos most of it aint cheap.
- moulder
the 2.0 Zetec is the same size as the 1.8 Zetec so it will fit in a 2i no probs.
the "bloke" with the mk1 is Graham.
- chumkila
- Dirty Post Whore!
The Yanks are in to fitting UDPs (Under Drive Pulleys) on their Zetec engines.
They replace the crank pulley that drives the water pump etc, with a smaller diameter, machined alloy pulley. Cos it turns the water pump etc slower, they reckon you can save as much as 6HP just by fitting one.
I've not tried one on my car yet, but I'm tempted. Anyone else tried one?
http://www.overboost.com/zetec/category.asp?id=2
http://www.unorthodoxracing.com/ultras.html
- grahamb
Moulder....only reason im fitting it into an Si is cos its one hell of a lot easier to do! You can simply plug a Series 2 Mondeo lump straight in (only have to swap a few bits n pieces).
Plus I've always quite liked the Si so thought i mite as well get one!
- Danny 2i
- The White 2i Guy!
- Your car: N/A
Graham is did see a test on these somewhere, and they gained around 1-2 bhp when they fitted the pulleys!!, if your gonna be revving it hard it may be worth it, just so the waterpump works right and doesn`t just put bubbles everywhere don`t know what sort of rpm it starts to do this though.
- snake
- Trainee Burger Flipper
- Your car: ford
Yeah id do that but i love me 2i even though iv only ever drove it round the block since I bought it. Well as long as it actually bolts in using the same engine mountings as the cvh, and I can use a zetec or cvh gearbox with the relevant drive shafts, the wiring is the least of my worries as me old man had been working with electricals for the last 40 yrs so he assurese me well crack the wiring. Any1 elseput a 2.0 inot a cvh and shed some light on the matter.
- moulder
I may fit one. Maybe the hose blew off from the pressure caused by the high revs. Bet it really was just me with a bit of brain fade though.
- grahamb
