tuning help
2 posts • Page 1 of 1
tuning help
i need my FRST tuning, it idles at abot 200 rpm, if that on cold, then on hot fluctuates between 200 and 500 rpm. quite worrying, as when u pull that plug thing off the idle valve it does NOT stall and it [ERRR] do!! dammit. and ontop of this its only running 8psi on max boost, but has a graph for 170bhp. so where is decent, burton area preff.....
- ianFRST
With the engine switched off, check your chip isn't loose - it should be on the bottom of your ECU.
The car should only stall with the ISCV disconnected when the car is cold.
Reset your base idle (Haynes manual chapter 1 I think) and have your CO levels checked.
- Project
- fiftyoneCL
