turbo conversion
6 posts • Page 1 of 1
turbo conversion
If i had a 1.6 8v xr2i, whats needed to convert to rsturbo please?
i know obviously engine and a turbo but what else???
john.
john.
- rsjohn
wot do you mean then mate?? if u put in a rs turbo engine wot else would you need, apart from the interior, bonnet vents rear pop out windows............
- dee_RS_2ltr
i think you can swap the pins on the loom to suit a turbo ecu (look in guides & faq) xr2i injectors, injection system & inlet are the same, fuel pump is diff but ive used a 2i one with no probs on frst. if the loom cant cant be changed or you dont want to fiddle, buy an engine loom off ebay etc. there are 2 ecu & loom types (ofac/ofab), so make sure they match up.
- samantha
