turbo management on fiesta turbo
1 post • Page 1 of 1
starting my zetec turbo conversion on my xr2i at the moment i have no efi turbo ecu or the map sensor to go with it so i will have to use the std xr2i management for a while i will look in to the management things side later just want to start the car up.my question is how much psi will i see from the std xr2i management i want to be safe for the time being need to no the max what i will get from it so i can set it down a few notches so i dont risk blowing the engine up.any ifo would be grate.oh im using the t3 turbo if that helps.
- MK4 Rick
- Your car: Mk5 Fiesta
