turbo pic wanted
14 posts • Page 1 of 1
turbo pic wanted
hi all, does anyone have a clear pic of an engine with twin turbos fitted where the twin turbos are clear in the pic so can see how they are all set up
- frstlad
- Your car: fiestas
from what engine?
- freak power
No reason why not, Two turbos for minimal lag instead of one big one, Still have the prob of running out of puff though i guess.
Maybe one big, one small turbo like some people are doing now.
well im building a 2.1 zvh with throttle bodies and a mate said i should 4 a luagh, now just seeing how it would work, would a t2 n t3 work? the t2 would kick in well but what would happen to it wen it runs out of steam, i no the t3 would then be ok but would the t2 burn out? is it poss?
if i did how would i run it to an intercooler, would i run the 2 pipes (one from each turbo) into a t-piece into the intercooler?
how would i also make the manifold? do u no anyone gd at making them?
- frstlad
- Your car: fiestas
- chris-fiesta
Turbo Technics did a twin turbo set up for the Cosworth a while back. It had two T2 turbos on a bespoke manifold. At low boost each turbo fed one pair of cylinders and at higher boost a valve opened in the manifold to allow both turbos to feed all 4 cylinders together. In a review I read the writer was impressed with the low down power and that it kept on pulling through the revs. I don't think they sold too many though, the manifold was some £2k odd ex vat. I also think they have a patent on the design.frstlad :nice one mate, has it ever bin done on a 4 cylinder engine b4?
- sailorbob
well i was looking at getting it made up, from the pics max put up with them twins before the maniolds looked quit simple to make for the right person!!
but all these valves in the manifold is way out of my range lol
would it work if i just used 1 turbo for a pair of cylinders? on a simple manifold setup?
i was tginking of using 2 T2's as i think that the t3s might not like half the power given to them as normal and might not spin up that well, the only prob i can think of the T2 is would it run out of steam top end?
i think someone said b4 that u can put a t3 setup in a t2 unit, is this true? if it is then that might be worth doing?
[ERRR] i dont wanna run out of steam wen im on the motorway, altho i do like the fact i could be off the line quick
- frstlad
- Your car: fiestas
