turbo temps
8 posts • Page 1 of 1
turbo temps
hi folks just had my fez turbo back with a new recon engine and when i was driving home from work the temp gauge was at 12,o clock "just befor the red" and the fan was on but the temp stayed the same is this ok as i thought the temp should go up to the "O" but no higher. But i know turbos run much hotter so this is why im asking is it ok to drive as everything seems to be fine
cheeRS matthew
cheeRS matthew
- Straight882003
Re: turbo temps
It shouldn't be that hight sounds like a problem has it got a front mounted intercooler? are all the water hose's hot? Try a new thermostat and i would gat a new temp sensor just to make sure the reading on the ghauge is right
- j7aoc
Re: turbo temps
its totally std but it was not doing this before i had the new engine because i replaced the whole lot i.e water pump, oil pump, thermostate, and thermo housing
and all hoses ect but ill get a new temp sensor cheers for your info buddy
- Straight882003
Re: turbo temps
Make sure all the hoses are warm as the coolant system may be air locked. Failing this the sensor could be broken or the thermostat stuck
Lower than a snakes bollox
- Big Walker
- Your car: Seat Ibiza
Re: turbo temps
cheers buddy ill check them tomorrow, fingers crossed lol
- Straight882003
Re: turbo temps
well all sorted my thermo was stuck so i baught a new 1 if only all problems were as cheap as this one thanks guys just need to run the engine in now
- Straight882003
Re: turbo temps
Straight882003 :well all sorted my thermo was stuck so i baught a new 1 if only all problems were as cheap as this one thanks guys just need to run the engine in now
I was right for once
j7aoc : Try a new thermostat
- j7aoc
Re: turbo temps
lol yeh pritty much spot on fella thanks for the addvise
- Straight882003
