turbos
4 posts • Page 1 of 1
turbos
do i have to run a turbo water cooled,i heard off somebody on here a while ago that if u did run water cooled u run a risk of blowing a head gasket,then on the other hand some people swear by using it.im a bit confused by all this .i will be running a oil cooler in the very soon to help with temps,.
- MK4 Rick
- Your car: Mk5 Fiesta
Re: turbos
You dont have to run water cooling on T series turbo's but do on GT's
3dr Sierra Cosworth Track car
S1 Escort RS Turbo
- wildheart
Re: turbos
im running a tdo4 froma subaru wrx
- MK4 Rick
Re: turbos
i would run water cooling...the way i look at it is if the cooling system is up to the job you should be ok...worst case scenario and if you are really worried...run water wetter (by radtec) as its a SUPERB product and helps BIG TIME on keeping engines cool...as well as that, a 82 degree thermostat and a lower operating fan switch all with help no end
bassboy
bassboy
- bassboy
- Authorised Trader
