Twin 40 DCNF Carbs
13 posts • Page 1 of 1
Twin 40 DCNF Carbs
Hi there,
New to this forum. could anyone tell me what the acceleration aspect is like with twin 40's, stage two mfi head, 1.6 xr2i bottom and standard xr2i cam? What kind of bhp figures are we looking at also?
- BlueFiesta85
Ok sounds good but the only problem is that there not running like that and ive had them tuned up aswell on a rolling road. The revs build up very slow as if it was on a single carb and the car just doent shift the way it supposed to. What could be the problem.
- BlueFiesta85
I had this problem.
Turns out the timing was out, due to a monkey in a previous garage not knowing what he was doing, and a air leak.
You should also get the carbs serviced, AND re-jetted. My car absolutley flew until I blew the rad apart last night and snapped a jet.
- Badgerboy
Ok mate ive got a stage 2 head with a xr2i camshaft which was just normally timed with the original pulley, also its running with a red distributor. What could be wrong [ERRR] im not getting the performance i should be. Please help.
- BlueFiesta85
Who set the timing, was it done in the garage? Have you checked for any airleaks?
Mine ran like a dog until a chap had a play with it yesterday. You should get the carbs rejetted as well, to suit the correct fuel flow.
What sort of fuelling system are you using? A facet pump?
- Badgerboy
Yes mate im using a facet fuel pump silver edition one. the timing was done by myself matched the notched up on the tdc and the bdc. However the jets were changed at redline tunning on a rolling road. Ive taken it there twice now and he goes its running fine but its not because like you said it runs very weak. A standard saxo 1.4 was quicker
- BlueFiesta85
BadgerBoy do you know if the starter device on the back of the carbs needs to be connected because my ones are not (Starter device - choke levers at the back of the carbs)
- BlueFiesta85
What does it mean if one of the carbs keeps popping and letting a spark out when your driving, because the first cylinder carb keeps popping evry time i drive the car what could be the problem?
- BlueFiesta85
