twin 40s on a 2i!!!!
21 posts • Page 1 of 1
i am gonna hopefully going to convert my 1.4 si to a 1.6 soon using an xr2i lump + loom ect.
but a m8 of mine has just given me some dellorto twin 40s which i hope to fit to the 2i lump when its fitted.
can i do this????? i know ill need a manifold but wil i need anything else????
cheers.
cheers.
- Mexi
yeah i have these mods planned as the engine needs a rebuld any way.
i am stuck on the fuelling side of things tho - what fuel tank can i use, wot fuel pump, also wot ecu (if any) and will i have any other problems???
- Mexi
ECU probably not a good idea. Try and run a normal mech dissy like one off a erst. Tanks and pumps will need to be changed or modified to standard carb tank and facet elec pump (carb one). Carbs run at low pressure, inj at higher, if you run an inj pump on carbs you just push the fuel through them and BORE WASH. It ain't too hard to do, well easier than inj cars. You probably won't have to fit the 2i loom in either if you run carbs, just get the essentials and make a new custom loom! Wire up sensors to custom dash and clocks. Should look fat, none of this wires everywhere that are useless that you get with a std loom.
- AdrianFRST
- Baby Battle Scratch
- Your car: ..? Pretty car..!
Car: 2010 Ford Focus RS
Yep, as the an said, except if your slapin in a cam I'd expect more than 140hp, Thats what I had with a standard cam.
- AdrianFRST
Where in the country are you mexicotom? I know of a guy that is the mac daddy when it comes to tuning carbs. if you want any help just mail me as I've done this already and have PROVEN excellent results.
- AdrianFRST
- Mexi
Oh bit far for the guy I think. Ask as many questions as you like, thats what I come here for, to answer questions and help fellow tuners, even though it seems I have to fight off the barrages of "thats not how mines done your a muppet" comments.
- AdrianFRST
FLIPPIN ECK!!!!!!!!!!!!!!!!!
are people not getting very bored of fookin arguing????
wouldnt be so bad if u knew one another but most of u dont!
i didnt post this thread to start an argument - i started it for information on my car!
the reason i think we all joined this forum?!?!?!
BYE!
BYE!
- Mexi
- AdrianFRST
Lol!
Boys! Stop it!
I have a carb fuel tank you can HAVE - take it off me!
The XR2i head can be converted to run a carb's fuel pump, but you may want to keep the EFi fuel tank and fit an adjustable regulator which allows you a lot more control over the fuelling.
As for wiring, there are about 3 wires needed to run a carb ignition system and if you buy yourself a race-spec dizzy it should come with everything you need.
Try Demon Tweeks for some ideas, then shop around for prices
Boys! Stop it!
- Project
- fiftyoneCL
error error
"The XR2i head can be converted to run a carb's fuel pump, but you may want to keep the EFi fuel tank and fit an adjustable regulator which allows you a lot more control over the fuelling."
Whoooh there nelly. Have you ver put twin 40s on a cvh? they take up about 1/2 the space where the pump goes! You need an after market electric fuel pump for carbs as they run at about 6psi and injection is MUCH higher psi. I have a spare pump kickin about if you want it its a facet red top pump, only the best will do! e-mail me if your interested or want any tips.
- AdrianFRST
