Tyres causing call to Pull to one side?
Postby Mav Singh on Wed Feb 20, 2013 3:13 pm
hey all, i got a odd problem, my car was pulling to the right, tracking was checked which turned out to be fine, new lower arms fitted too and its still pulling to the right.
so i swapped the 2 front tyres over left to right.
now the car pulls to the left making me think somehting is not right with the wheels/tyres?
can tyres cause a car to pull in one direction? air pressure is equal on all tyres.
i cant see any dents or cracks on the rim so wondering if its an issue with the tyres or the rims?
1.6 si
Mav Singh
Your car: 1995 Fiesta Si 1.6
Re: Tyres causing call to Pull to one side?
Postby trecoll on Wed Feb 20, 2013 3:27 pm
Are they directional tyres on back-to-front?
trecoll
Postby mikeymikeyp on Wed Feb 20, 2013 3:38 pm
The tyres could be warped ,need them on a balance machine to see it
or you could jack it up and run the wheels im sure you would notice if the tyre was wobling
mikeymikeyp
Postby Mav Singh on Wed Feb 20, 2013 3:48 pm
nop they are not directional tyres, they got assymetrical tred,
however 1 tyre looks odd, from the side it seems fine and round but if u look at it directy from the tread it looks like half of the tyre is bigger than the other half.
if u get wot i mean.
1.6 si
Mav Singh
Postby FRSJON on Wed Feb 20, 2013 7:54 pm
my monies on a out of shape wheel.. just had the same thing on my van..swapped wheel and all good :)
swap wheels from front to back :)
FRSJON
Postby ~S1~ on Wed Feb 20, 2013 10:38 pm
The tyre has worn unevenly so even though the car is tracked up straight it still pulls to one side. Try sticking the tyres from the back onto the front.
~S1~
Hold On...
Hold On...
Postby Mav Singh on Thu Feb 21, 2013 9:43 am
got new tyres will get them fitted on saturday and see how things go. will post back with results.
1.6 si
Mav Singh
Postby Mav Singh on Sat Feb 23, 2013 12:08 pm
changed both front tyres today and the car drives awsome, no more pulling to one side and its super smooth, feels like a new car now.
the firestones i had on were new but suffering from radial pull, they s**t,
rainsport 2 on now and good
1.6 si
Mav Singh
Postby andymac on Sat Feb 23, 2013 1:21 pm
~S1~ :The tyre has worn unevenly so even though the car is tracked up straight it still pulls to one side. Try sticking the tyres from the back onto the front.
That, also should be careful if replacing a single tyre, sometimes manufacturers change compounds or tread patterns and the difference can cause a pull to one side. Had this on my car when I bought it, tyre sidewalls proclaimed themselves to be identical but the tread patterns were different.
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
