Under 25's Trackday Snetterton100 June 4th - £75
Postby ClubMSV on Thu May 03, 2012 5:15 pm
The brand new technical track of Snetterton 100 is a fantastically challenging mini circuit. At just under a mile long it has everything to offer, with the high speed straight, the technical corner of Oggies and the sweeping bend of Hamilton.
Our new under 25’s track days offer younger drivers an excellent opportunity to not only get out on track but learn skills that will last a lifetime.
For the unbelievably low price of £75 you will not only have a day out on track but also included is free entry into the trackday class room sessions throughout the day as well!
At the start of the day the instructors will be on hand to help you carry out the pre-track checks that every driver should perform before going out on circuit making sure your car is always safe, roadworthy and ready to go!
The class room sessions will cover areas such as braking point, with techniques like heel and toe and cadence braking, turn in point and how to hit the apex while controlling weight transfer, as well as exiting the corner smoothly and effectively. Once you have found your braking point, the instructors will teach you how to brake that bit later so that you can carry more speed through the corner.
For any under 25’s that want to see what trackdays are all about without committing to the full day, 20minute Taster Sessions are also available at just £15!
You will receive:
•A full safety briefing including track driving techniques.
•Three limited speed laps led by a safety car so that you can familiarise yourself with the circuit and learn the racing line.
•The remainder of the session at your own speed.
All participants must be between 17 and 25 years of age with a full valid UK drivers licence.
To book visit - http://www.clubmsv.co.uk/car-home/event ... uctid=1472
OR
Call - 0843 453 3000
ClubMSV
Your car: mk5 Zetec S track car
Re: Under 25's Trackday Snetterton100 June 4th - £75
Postby ClubMSV on Fri May 25, 2012 11:08 am
Limited space on this one due as the numbers out on track are limited per session!
ClubMSV
