Unichip
6 posts • Page 1 of 1
I recently got told that if i wanted to use a unichip, i would have to get a second chip to bypass the over boost protection, is this true ? or should i just stick with my Superchip stage 1 ?<br>cheers,<br>Greg
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
- Fezzy Turbo
A superchip is cheaper<br><br>and can easily be removed - which injectors are you running ?<br><br>Mike.
- Mike Gurney
It cost me £587 for the unichip module, boost limit chip, and fitting. The good thing about them is that you can add units onto the unichip, 5th injector, boost controller etc. It can also be used to run a zetec if I go down that route. I shall be getting it remapped when i`ve finished the T3 conversion.
- snake
- Trainee Burger Flipper
- Your car: ford
Mike, i am still running the standard injectors as i only have 161bhp @ 10psi. I am waiting until my standard turbo goes then get a hybrid and larger injectors etc.....saving money now!!<br><br>Snake, cheers, i had heard that once you pay the initial cost of getting the chip, etc.. then it can easily be re-mapped, which obviously saves on buying a new Superchip
- Fezzy Turbo
