Upgraded speaker cable
9 posts • Page 1 of 1
If I change the rubbish speaker wire in my car at the moment for better stuff will it improve the sound quality at all? What cable do you recommed? x
- adamjbinnie
Re: Upgraded speaker cable
changing the speaker wire from the standard ford stuff is better , just get some average speaker cable works just fine but dont expect a massive difference in sound quality and using decent connectors helps aswell.
- gumpy
- Location: barry, south wales. drives: fiesta xr2i replica
i wouldnt expect to gain anything with Ford speakers, but with aftermarket stuff it works a treat.
- properphatboy
- Your car: Peugeot 306 D L
wont help much unfortunately...but if running OE equipment..any oxygen free cable will be fine...and believe it or not...any oxygen free cable for most installs is perfectly fine!
bassboy
bassboy
- bassboy
- Authorised Trader
Seen some installs that have several smalller wires all wrapped together for each channel. Doubt very much most people would notice any difference.
I tend to just use OFC cable that I got on a drum from my local car Hi-Fi place when it closed.
I've currently got some Sony 6x9s and some Kenwood components, both rated well over the 50w per channel my CD player puts out, yet I still get distortion at volume level 22 or so (out of 50). I'm sure it used to go louder in my old car where I had proper speaker wire, rather than using the Ford wiring like I have in this one. I'll rip all the wiring out and see if it makes a difference! Cheers for the help.
- adamjbinnie
Bear in mind the power supply to the stereo too then. If it's not able to get enough electric it may start distorting stuff.
- properphatboy
It's connected to a wiring harness and then to the Ford stereo...plug...Is there a better way of connecting it?
- adamjbinnie
Yep. By running a thicker, fused wire to the fusebox or battery.
- properphatboy
