Upgrading brakes
27 posts • Page 1 of 1
Upgrading brakes
For all u techies, i was just thinkin, for that same price as gettin some uprated discs and pads, i could get some cossie brakes or similar.
So, i have a lot of questions. If i were 2 change my front brakes completely for cossie ones on mondy ones etc, what do i do/need?
I'm guessin the calipers, discs, pads and mounting bracket?
What brakes fit from other fords? obviously they'd hav 2 b from a car with the 4 stud fit, not the new 5 stud, but what about offset? does this make a difference with brakes? will the centre of the disc b different (thicker or thinner) or summit? Also, would it b cost affective because i'd have 2 buy brand new cossie discs and pads or even uprated (standard size, just better compounds etc) cossie discs and pads.
I know theres allot of questions, but i'd like to know everything about changin brakes b4 i buy n e parts. This has come about because i saw gadgets for sale post where he sold Stoned some brand new brakes ( i think calipers, discs and pads, although i'm not sure) for a really good price, and i want some good front brakes so i can go for the z-s rear beam and focus brake route in the future.
Tom
Tom
- Sphinx
Yeah it was a good price. But I havn't tried them yet. If they turn out to be crap and I die in a car crash you can feel free to take them off the wreck
Anyhow. Mondeo ones will fit as long as they have been machined slightly like Gadgets ones. Cossies ones also fit but use washers to space things out which is a bit naff.
ST170 brakes are 300mm and apparently fit with a space plate made up. These would be awesome and the ones to get I reckon
Alternativly Escort RS2000 brakes are an upgrade but fit straight on. These are 260mm discs so not massive, but defo much better than the standard 240mm discs.
I got a set of these on mine and are fine for my current power of 150bhp but I wanted new ones for the future bhp.
- Stoned
Cheers lads. Dan, wot i'm sayin is, u've got bigger discs rite? so therefore the mounting bracket for the caliper must need 2 b extended 2 reach the edge of the disc
- Sphinx
i paid £130 for my callipers then paid £108 to get them reconed.
£100 for some drilled and grooved disks
and £60 for some standard ford sierra 4x4 pads.
i got my disks and pads cheap if ure paying retail id expect to pay about £70 more
+ £30 for some braided hoses
id budget for £500 or unless you can find a cheap way of reconditioning the callipers or risking it and leave them.
The 300mm conv requires 16" wheels a good way to go if u got the room but cosworth fits straight on with longer bolts and a few spacers.
hey they can stop a huge sierra they will be fine or ure fiesta
- MadcatCraig
- BANNED SELLER
Sphinx, the calipers include the extended carriers, bolts, pads and everything, all brand new for £200, and new discs are bout £100 from ford. All that is needed then is some braided hoses and they are perfect.
- dannyboy
sphinx :Cheers lads. Dan, wot i'm sayin is, u've got bigger discs rite? so therefore the mounting bracket for the caliper must need 2 b extended 2 reach the edge of the disc
Nope, the MATCHING caliper for the 300mm disc ( ie the Focus st170 caliper ) is already done on the anchor brackets, so no brackets needed as Dan says!
Dan bought a 300mm set from me and stoned bought a 278mm kit!
- Gadget
- Your car: 05 Mondeo ST Tdci & FRST
Ive just fitted a set of 278mm cossie's to my fiesta, so much better even with cak greenstuff pads, just goto save some cash for the new discs and pads!
Jonzy
Jonzy
- jonzy@sw-cc.com
And remember to use braided Stainless steel brake hoses
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
TJ :Fezzy Turbo :And remember to use braided Stainless steel brake hoses
Bollox! Thanks, gotta phone the mechanic i knew there was summin else i wanted done while he's doing the MOT!
No problem.................. i thought someone would have said earlier
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
Stoned :Are those 300mm kits duel metal Gadget, so alloy bells and metal discs?
Cos otherwise 300m metal discs have got to be pretty heavy?
no mate, all 1 piece, not too heavy though
- Gadget
am i right to assume that all i need to do is find a old Sierra and get the bits of em with new bits to go with em?
- penfoldian
Ive jus bought some 4x4 Cossie calipers orignal from an Escort and nearly new discs for 130!
Gonna get them fitted when she comes out in spring.
- MIK3Y
- chumkila
- Dirty Post Whore!
dannyboy :Sphinx, the calipers include the extended carriers, bolts, pads and everything, all brand new for £200, and new discs are bout £100 from ford. All that is needed then is some braided hoses and they are perfect.
And thats the the 300mm set rite...GAAAADDDDGGGEEEETTTTT!!! can i have some of these please?!
Also, wot size are the focus discs used on the rear beam conversion on the Type-R? I've red the the post but cant find wot size they sed.
I'll put the escort master cyliner on @ a l8er date. As u can tell, i want amazing brakes BEFORE i get the 2.0 in
- Sphinx
