upgrading to xr2i clocks help
Postby b0yracer on Mon Oct 11, 2010 8:44 pm
hi, im going to fit a set of clocks with the rev counter into my fiesta 1.1 (just have speedo fuel and temp gauge on mine) will i need to get any wiring loom plugs or such like? or is it a matter of plugging it straight in. will i need to add a wire for the rev counter?
ive done older fords mk2 escort etc where its just a matter of swapping the wires round a bit then plugging in
just wondered if any of you guys have done this on mk3 fiesta
thanks
b0yracer
Your car: ford
Re: upgrading to xr2i clocks help
Postby curly on Tue Oct 12, 2010 10:54 am
there are aload of guides about this, it all depedns what the dials have come out of, and how basic your 1.1 is,, model wise, some cars have got a rev counter wire plumbed in, some havent, youll uslually have to take a feed of the edis, and wire it in to the clock connector,, and sometimes, with the aid of a supressor,,
[HOONIGAN]
main priority!!!
A-B-U-S-E-!-!
curly
Postby b0yracer on Tue Oct 12, 2010 2:23 pm
ok cheers ill have a look see whats what
i know that suppressor your on about had one on a g reg 1.6 fiesta. but what does it actually do?
b0yracer
Your car: ford
Postby curly on Wed Oct 13, 2010 1:09 am
im sure someeone will corect me if im wrong,
it basicly cuts the currents running through the wire, taking away the bad bits,, lol( leaving the good bacteria :D )
so yeah cust the current,,
[HOONIGAN]
main priority!!!
A-B-U-S-E-!-!
curly
Postby jonyb4 on Wed Oct 13, 2010 6:26 pm
yes but since theyre different engines, the XR one may not work, there are some 1.1s out there with the rev counter, or even the 1.3 one would work, but yes you need to tap intot he green wire (2nd in from left ont he edis int he engine bay fire wall)
check out the guides on fiestaguides.co.uk it has it covered on there, with a list of the engine types per clocks setup
Postby jakerowles on Fri Nov 19, 2010 11:46 pm
mines allready got the green wire its a mk3.5 1.1 sovereighn what clocks do i have to use for the rev gauge to work properly ?
jakerowles
Your car: Fiesta
Postby jonyb4 on Sat Nov 20, 2010 2:47 am
not sure about that, there were a few number of 1.1/1.3 ghia's which likely had a rev counter in
you can try the XR2i counter, but yet again it could miss read, or you can simple buy an aftermarket tachometer
and wire it into this green signal wire
Postby b0yracer on Sat Nov 20, 2010 2:01 pm
i was maybe flukey but i bought my fiesta clocks off ebay as i didnt realise that they were different
but mine were from a M reg 94 fiesta 1.6 si
i had to add a wire i took it straight from the back of the rev counter to the 2nd wire (green) on the edis plug
mine work fine
b0yracer
Your car: ford
Postby jonyb4 on Sun Nov 21, 2010 12:17 am
bloody hell thats lucky
would never have thought the Zetec edis would be compatible with the HSC one :oooh:
Postby b0yracer on Sun Nov 21, 2010 4:53 pm
mine works spot on so im happy :D :D
b0yracer
Your car: ford
Postby curly on Wed Dec 15, 2010 6:59 pm
your learning quick young chap haha,, its good when things workafter blind luck, :D
[HOONIGAN]
main priority!!!
A-B-U-S-E-!-!
curly
Postby b0yracer on Wed Dec 15, 2010 11:13 pm
bubi :your learning quick young chap haha,, its good when things workafter blind luck, :D
ive not been called a young chap for a long time lol :D :D
b0yracer
Your car: ford
