uprated rad for a 2.0l silvertop mondeo
10 posts • Page 1 of 1
hi guys,
just curious as to whether i can find a better rad than the 1.6si rad i will be using?
thanks, Ben
thanks, Ben
fifi
- ben17southport
Re: uprated rad for a 2.0l silvertop mondeo
no need, you should be ok with the one that you already have, change the coolant and replace for another rad if the one ur using has seen better days, if the engine does start to getr a bit warm fit a nice high performance slimline fan. some people even fit oil coolers
- scottybo
- Your car: mk3 frescrati
Ive got a nice alloy Mondeo radiator in my mk4 fiesta and it does the trick
- MK4 Rick
- Your car: Mk5 Fiesta
thanks lads, will look into it when its up and running
fifi
- ben17southport
did you ever find an uprated radiator? id like one for my 1.6 si.
1.6 si
- Mav Singh
I didn't mate but I imagine your 1.6 will be fine. I've thought about buying a brand new 1.6 rad but it's finding one that's the issue. That's the road I'll probably go down anyway as I haven't enough power to justify an alloy rad
fifi
- ben17southport
can a alloy rad be obtained for the si though? would like to know more on this.
1.6 si
- Mav Singh
would have thought a normal alloy rad from an rs fiesta would do if it has the same fittings. I know on escorts for 16v theres an alloy rad for an rs2000 but all the rads are the same size and same fittings
- SLEEMAN
If it helps I managed to get a rad from eurocarparts
- willowandmikey
Did it fit? I had a mate who had issues with one, was missing a connection on it.
fifi
- ben17southport
