URGENT: Sprayin a 2i spoiler!!!!
Postby Robz_Fester on Tue Sep 18, 2001 7:06 am
What primer or whatever did everyone use, painting it with a spray gun and it's just peeling off :mad:
PLEASE SOME1 HELP!!!
Robz_Fester
Postby TJ on Tue Sep 18, 2001 9:00 am
I used spray primer from autocolours i think.
TJ
Postby TimEdwards on Tue Sep 18, 2001 12:17 pm
just sanded it down - used grey halfords primer (the colour primer for your colour paint will be different) them bought the paint from ford (which was an exact match and the laquer came with it) waited 24hours - sprayed colour - waited 3 hours - sprayed laquer - waited at least 24hours then put it on my car.
What probs you had?
TimEdwards
Postby Project on Tue Sep 18, 2001 1:55 pm
400 grit, then vinylkote it, then plastic filler primer, plastic primer and finally basecoat and lacquers. Use 800 grit wet 'n' dry after the vinylkote and 1200 and then 1500 for the others. Several coats of each and make sure you swab the spoiler before applying the vinylkote.
Al
Project
fiftyoneCL
fiftyoneCL
