Using a break setup from another car: what do i need to know
5 posts • Page 1 of 1
If ive found a break set up that fits another type of car, what details do i need to know about this car to figure whether the same set up would fit the fiesta (e.g offset?)?
- DaveMCMkIII
you'll probably have a lot of hassle getting them to fit to be honest. Im pretty sure the disc mounting holes will be different for starters, and the caliper mounts will be different also. You're best off sticking with Ford products if you want to use manufacturer products as opposed to aftermarket stuff like AP and Hi-Spec. Have a look around for a brake set-up from a Cosworth 4x4, these are just about a straight fitment on Fiesta's and will give a marked improvement in the braking performance.
- Pez
