V6 Calipers
4 posts • Page 1 of 1
V6 Calipers
evening guys/gals, just a quick one if youd be so kind
I've picked up a pair of Mondeo V6 Calipers to go on the Si as part of the necessary brake upgrade to cope with the soon coming Zetec Turbo lump.
Can someone confirm that the V6 calipers are the same as Cossie 4x4 calipers, ive been told that they are, but i wanna check this.
also with regard to fitting, im assuming fitment is similar to the cossie setup which requires spacers and the bolt holes re-drilling and tapping from 10mm to 12mm ??
i could only find a guide for the cossie upgrade, but if they calipers are the same, obviously the guide will apply !!
cheers peeps
xander
cheers peeps
xander
- xander7
Don't need to tap, just open the holes out so the bolts fit.
Fitting is same as Cossie - same hoses, same amount of shonky spacing, etc.
/Munk
/Munk
- Project
- fiftyoneCL
- Mikee_RS
Car: 1995 Ford Fiesta
