Van Aaken...do they know what they are doing??
22 posts • Page 1 of 1
Hi I am posting this on behalf of a mate. He's having a turbo conversion on a Zetec-S with Van Aaken. They kindly melted 2 of his pistions while "professionally setting up" his car.
I was just wondering if anyone else has had problems either with turbo conversion or with Van Aaken in general.
CheeRS
CheeRS
- EssexRedFRST
they had a van aaken converted zetec s at interpro it wanted to go on the rollers and the opporator wouldnt let it due to problems he thought it had !
for the money why ?
i hope there replacing the pistons
really should be forged items with a turbo and if they aint why are they melting them running at low boost
for the money why ?
- MadcatCraig
- BANNED SELLER
- chumkila
- Dirty Post Whore!
depending opn what conversion they do would determine what type of pistons they would use.
the low boost turbo conversion only runs at around 7 to 8 psi if i rememeber correctly. hence using std pistons.
try keep the abusive opinions to a minimum people, have heard of a few sites being shut down recently due to 'over zelous' opinions on outside companys.
sorry for treading on toes Ade
- Mexi
- chumkila
- Dirty Post Whore!
Mexi :depending opn what conversion they do would determine what type of pistons they would use.
7-8 psi is not low boost
a FRST or ERST runs that as standard and they were made with forged mahl pistons and fillet rolled cranks for a reason !
low boost would be a couple of psi
- MadcatCraig
- BANNED SELLER
er Craig why do you insist on having to argue?
i was merely quoting that the van aaken 'low boost kit' runs 7 to 8 psi.
thats it, theres no opinions invovled!
- Mexi
MadcatCraig :Mexi :depending opn what conversion they do would determine what type of pistons they would use.
Well bugger me backwards for christmas cos the 2nd generation t series rover turbo engine didnt use forged pistons but ran at about 7psi...
The original engine used forged mahle pistons and is good for higher boost applications. The "chocolate" pistons used in later engines had a tendancy to melt under higher boost (12 psi+)
That is why i'm using the earlier engine with the forged pistons.
Nothing to see here...
- andymac
- Elite Pie Master
In a word, the management simply throws a paddy, and without a lot of work to modify the fuel and advance curves (which I'm of course sure Van Aaken have spent time and money researching), there is simply no point in trying to release power through this method.
So, my question is, exactly what changes to the car's management set up do VAD make to the Ford EEC-V management?
- Project
- fiftyoneCL
Mark Si :They put a pretty sticker on the ECU saying 'Proffesionally tuned by Van Aaken Developments'
I cant' believe that's all they do ?! They woudl surely be liable under the amended consumer rights acts if that were the case, specifically the sections relating to fitnees for purpose.
- andymac
- Elite Pie Master
- chumkila
- Dirty Post Whore!
not everyone has had bad experiences with VAD.
have heard alot about their diesal optimising treatments over the past year.
had one chap in with a corsa td who had had the car optimised and had returned with 20 od bhp more, he couldnt rate them highly enough.
- Mexi
A big thanks to all of you who have put your views forward, will be showing my mate soon. I hope i haven't gave the moderators a touch time with this as it seems quite contraversial!!!!
Many thanks again
Off to Power Engineering...now there's a good place! (oops done it again!)
Many thanks again
- EssexRedFRST
true there have been some people slating them, but if they have done bad work people have the right to know, just like ian howel gets good comments about him... same thing just different feedback
- Phil Si
Car: 2000 BMW 330 Ci
Mexi :not everyone has had bad experiences with VAD.
possibly mate, quite possilbly.
i have however had real bad experiances with VD though
- 285Andy
- Your car: fiesta rs turbo
so i would respect your opinions on their work Andy
IMO you have to have had experience with someone to pass judgement
- Mexi
285Andy :Mexi :not everyone has had bad experiences with VAD.
wont be shaking ur hand then
- Phil Si
