Vibra tech gearbox mounts
26 posts • Page 1 of 1
Well my original ones have gone. What you'd expect from a J reg turbo.
Just wondering if anyone has use Vibra tech mounts and were they anygood?
- Escort Cos
yes matey, ive got em on my fes, cost a fair amount, but well worth the money imo, the engine is completely solid and will stay like that for some time i expect, the car feels more responsive compared when i put the new standard mounts in as it just doesnt move!!
hth, rolls
hth, rolls
Xr2T
- Rolls
Cheers, I ordered some at lunchtime (£92 for 2 gearbox ones) as mine are completely shagged and the cross over pipe has been hitting the underside of the bonnet.
Just gutted they don't make the engine one.
- Escort Cos
May i ask where from mate. My cross over pipe is touching the bonnet aswell. Is there only three mounts and you get the third from Ford?
Approx cost anyone?
Matt
Approx cost anyone?
Matt
- StreetDragster
That was from Amber Performance mate.
The engine mount has to come from ford apparently as Vibra don't make one but I dread to think how much it would cost.
Only three mounts, 2 for the front and back of the gearbox and the engine mount.
- Escort Cos
Thanks!
I'm going to get the gearbox mounts aswell, i'll ring Amber tomorrow and order them, but i'm planning on doing the ZVH conversion in December so i will need to modify the remaining 'engine' mount, so i'll get a new one then.
Thanks for your help
Matt
Matt
- StreetDragster
People on here say if you are getting ford mounts to get the diesel mounts as these are stronger than the FRST mounts.
Might be worth knowing if you are going to get 1 ford mount.
- Stoned
U hav to modify the desiel mount to fit the RST i think i remeber some1 saying, ive got Vibratech mounts and rather than the engine vibrating IN the car, the engine vibrates the car!
Bit of a pain, not sure if they r worth an extra £45 over originals though. At least it's another fix done properly.
- MIK3Y
Ordered my Vibratech mounts and Morrette headlamp conversion this morning, Escort Cos got the last set of mounts so i have to wait a few days lol
Matt
Matt
- StreetDragster
Mine arrived today, Are you supposed to have two of the same mounts??? (Part Number FOR62M)
Just thought i'd check before i took the car to pieces to fit the wrong mounts
Matt
Matt
- StreetDragster
Yeah, there exactly the same mate. I'm fitting mine on Thursday. I hear the back rear one is a bit oa Bic™ to fit.
- Escort Cos
Nice one! Thanks for your help, let me know how it goes, i've got mine to do saturday afternoon/sunday
Matt
Matt
- StreetDragster
Did mine yesturday, not too bad a job, needed some tools i didn't expect to need, like a 15mm and 18mm socket and spanner (though that almost all bolts on Fords are 17 or 19) Its a pain in the backside to get the engine cradle back ont he new mounts, i loosened the front mounts bolts which connect it to the gearbox to give a little flexibility then tightened them all back up once its on.
Engine doesn't move more than 1/4 of an inch now, delighted with the Vibratechs
Matt
Matt
- StreetDragster
Re: >
MIK3Y :U hav to modify the desiel mount to fit the RST i think i remeber some1 saying, ive got Vibratech mounts and rather than the engine vibrating IN the car, the engine vibrates the car!
Your right, they do vibrate the car, but they don't half make the car feel better. One of the old ford ones fell apart when I took it off.
- Escort Cos
Agreed, the car feels *alot* better, and clutch bite feels better aswell, highly reccomended
Matt
Matt
- StreetDragster
StreetDragster :Agreed, the car feels *alot* better, and clutch bite feels better aswell, highly reccomended
Matt
Yep, thumbs up for Vibratech. Your defo right about the clutch bite and shifting gear is much much better.
- Escort Cos
Errr approx 165 i think, but after reading a thread about Bajoo chips i'm not sure. Engine improvements are-
Rebuilt 1600cc
Kent Camshaft
T25 Hybrid Turbo
Ram Air Filter
Scorpian Exhaust
Amhed Bajoo 165 Chip and actuator running 14psi (on Nomad Gauge)
EBC Clutch
Standard injectors, intercooler etc etc
Matt
Rebuilt 1600cc
Kent Camshaft
T25 Hybrid Turbo
Ram Air Filter
Scorpian Exhaust
EBC Clutch
Matt
- StreetDragster
You are running a standard intercooler on that setup
Dude get something better. You will be losing power on that pissy intercooler. At the very least get a pace intercooler or better yet get the GRS one GavRST has. It fit's right in the middle of a standard FRST bumper and gives much lower temps for lots of power
With that and your setup you should be getting around 175-180bhp
- Stoned
Yep, standard i/c for now, i'm planning a full zetec conversion around xmas time when my garage is finished (1/2 way through construction now) and i thought it may be in my best interest to fit a bigger rad and intercooler at that time, rather than fit it now and have to modify it if, say, a pipe is in the wrong place, or interferes with another pipe or something.
Just wondering about my injectors as to whether they need changing etc.
Matt
Matt
- StreetDragster
Hi there,
I'm also running on Vibratech (fast road.. Fiesta MK3,Escort mk4) mounts.. and a Diesel Engine mount
(just a small adjustent has to be made.. and costs the same as the FRST one does)
just file up the slots of the original mount from 10 to 12mm .. and use a bolt wich will go straight thru the mount in stead of 2 seperate threads.
Vibratech vibrates your car for sure.. but the feel is WAY better..
and ehhm .. i was running 175BHP on a T2 at 14 psi .. with the standard I/C ... still looking for a bigger (pace/GRS) one. .
- Jur
