Vibra-Technics engine mount for mk3 rst
10 posts • Page 1 of 1
I guess this is the right section..
I need a stiff engine mount to keep my engine from moving too much but it seems i can only find vibra technics gear box mounts. is thee any companys out there that do stiff engine mounts?
- Ram
Re: Vibra-Technics engine mount for mk3 rst
Vibratechnics are all you need
- hb69
- Your car: Fiesta 1.1 LX
yes but i can only find mk3 fezzy gearbox mounts and not engine mounts (the one that mounts to the actual engine block)
would be happy to buy a vibra one if i could find it!
- Ram
sure someone on here had a good result filling a standard one with silicone
- dangerousdave
doubt a solid engine mount would make any difference.its the gearbox mounts that do all the work, with vibratechnics gearbox mounts there should be little to no movement from the engine
- hb69
go to vibra technics direct they do one for front mount on engine side too like on rs1800
- dug112y
i was supprsed to see that they make a gearbox mount for the mk4/puma, the torque stabiliser on the bottom
Thanks guys will try them direct.
The problem is with my screamer pipe poking out the bumper theres too much movement and its rattling/whacking my bumper.
you can see the forward and backwards movement in the standard mount on left side of engine.
- Ram
Ram, i have two soild gearbox mounts that i used with my quaife gbox i had.
there made out of soild steel and kept the engine still,but they increase the vibrations.
i dont need them anymore if your interested you can have for 50.
- SEG1
Cheers for the offer mate but seeing as im getting the car ready to sell i prob need something abit less hardcore and user friendly lol
- Ram
