wanted door cards
Postby rs van dan on Wed Sep 27, 2000 11:24 am
has anyone out there got any fiesta rs turbo door card i cant find any anywhere please help
rs van dan
Postby rs van dan on Tue Nov 07, 2000 12:01 pm
I found some rs 1800i ones they r near enough the same u cant notice unless u know they are differant or u r looking for it
rs van dan
Postby RS1800I on Wed Nov 08, 2000 5:07 am
YES THAY R !<br>THE BOTTOM AND THE PLASTICK SHOULD BE BLACK WHERE AS THE TURBO IS GRAY !<br>UNLUCK MY FREND !
RS1800I
Postby flea_bateman on Wed Nov 08, 2000 7:45 am
try the south london fiesta turbo centre<br><br> <A HREF="http://www.slfiestaturbocentre.co.uk" TARGET=_blank>www.slfiestaturbocentre.co.uk</A> <br><br>They have anything to do with a fiesta.<br><br>Good Luck
flea_bateman
Postby Project on Thu Nov 09, 2000 12:50 pm
What's wrong with your current cards?<br><br>(Don't laugh too much) - I used some black sub-box carpet on mine, after pulling off the stick-on vinyl and carpet (piece of p*ss). Looks a proper treat and not too rough. Also, easy to clean, doesn't rot (made of plastic, y'see) and you can take it off and replace with a different colour if you're so inclined.<br><br>It's not too hard (at all) to cut out XR/RS door handle holes if you've got L/LX cards with mini handles.
Project
fiftyoneCL
fiftyoneCL
Postby flea_bateman on Fri Nov 10, 2000 10:20 am
Project Fezzie.<br><br>Have you got any pictures.<br><br>It sounds a good idea but I wouldn't mind seeing a finished version before I start messing about with my door cards.<br><br>Cheers
flea_bateman
Postby rs van dan on Sat Nov 11, 2000 7:36 am
your right rs1800i i have the black door pockets etc i just need a black dash board what models come with them??
rs van dan
Postby RS1800I on Sat Nov 11, 2000 9:21 am
THE FIESTA RS1800I HAS THEM NOT SHOR ON THE XR2I 16V . Y DONT YOU JUST GET AN RS 1800I INSTED. THERE ARE A COUPLE OF RS1800I BEING BROKEN IN PERFORMANCE FORD . TRY 01422 376775 HE HAS FULL INTERIOR FOR £250 OR TRY THESE SHOPS THAT I NO HAVE THEM . THE RS SHOP ON 0115 975 1548 OR TRY 01202 547070
RS1800I
Postby Project on Sat Nov 11, 2000 1:38 pm
I'll see what I can do, but don't hold your breath 'cos I don't have access to a scanner at the mo'. I have also taken out stowage pockets and speakers, although that was simply for a separate project which never happened.<br><br>You can "test run" by stretching some black cloth (i.e. bedspread, sheet, etc) over the card, hold it down at the back and then screw everything back on - the screws will make their own way through the cloth with a little persuasion, and you can just whip it all off to do the job proper.<br><br>Hey, there's an idea - seat covers and matching door card covers to fit tilt seats for the Fez. Anyone wanna go?????
Project
fiftyoneCL
fiftyoneCL
Postby rs van dan on Sun Nov 12, 2000 2:11 am
cheers buddy i will give them a try monday
rs van dan
Postby rs van dan on Sun Nov 12, 2000 2:12 am
cheerds buddy i will try them monday
rs van dan
Postby RS1800I on Sun Nov 12, 2000 10:57 am
RS VAN DAN !<br> WHAT IS YOURE VAN ? I AM DOING A CONVERSION , I'VE GOT THE ENGINE BUT I DONT KNOW WHAT TO PUT IT IN , A FIESTA OR A ESCORT COMBI ? ANY IDEARES ?<br>
RS1800I
Postby rs van dan on Mon Nov 13, 2000 7:35 am
my van is a 1.6 petrol (xr2 engine) with cam pcs zorst<br>Exterior: cosworth front bumper<br> mark 4 fiesta rear bumper, rsturbo arches. flushed boot delocked and dehandled clear lights all round (ind,Rear lights)<br>turbo suspension plus spax springs (60 mm)<br>15" wolfrace genisis rims<br>turbo seats 1800i door cards back boarded (not carpeted yet) im getting there
rs van dan
Postby rs van dan on Mon Nov 13, 2000 7:40 am
as for ur conversion i would go for the fiesta 2 reasons<br> 1 handle better <br> 2 more bits available as its the same body as the car<br> but i supose im a bit bias as i have got one
rs van dan
Postby RS1800I on Sat Nov 25, 2000 7:08 am
IVE GONE FOR THE COMBI , ENJINE GOING IN SOON<br>
RS1800I
