Wanted
7 posts • Page 1 of 1
Wanted
Im after the 2 litre zetec inlet manifold with the sandwich plate the 2 litre injectors,fuel rail conectors and the 2 litre throttle body to bolt to my 2 litre blacktop.It doesn't have to be the ho inlet it can be the so inlet that's been modded
- MK4 Rick
- Your car: Mk5 Fiesta
Re: Wanted
Don't bother with a SO inlet, stuck to a HO.
All sandwich plates from a 1.8 are the same and have the right port size to fit a HO inlet
Re: Wanted
Does that mean you are looking for a focus inlet manifold? I have a 1.8 escort gti plastic inlet manifold for a silvertop engine with 2.0 injectors and a throttle body too if that helps?
- SLEEMAN
Re: Wanted
jayrs :Don't bother with a SO inlet, stuck to a HO.
Cheers Jay
- MK4 Rick
Re: Wanted
SLEEMAN :Does that mean you are looking for a focus inlet manifold? I have a 1.8 escort gti plastic inlet manifold for a silvertop engine with 2.0 injectors and a throttle body too if that helps?
Im looking for the fiesta,escort ali inlet
- MK4 Rick
Re: Wanted
Ive got an SO inlet, and the sandwich plate and a couple other associated bits. If you can hang on for a day or two ill take a look for them. Inlet is black IIRC.
Ka RST - 200BHP!
- hobomassiv
Re: Wanted
hobomassiv :Ive got an SO inlet, and the sandwich plate and a couple other associated bits. If you can hang on for a day or two ill take a look for them. Inlet is black IIRC.
Cheers mate let me no exactly what you have please
- MK4 Rick
