water HELP ASAP
water HELP ASAP
Postby Straight882003 on Sat Nov 04, 2006 12:54 pm
CAN ANY1 TELL ME HOW TO BLEED THE WATER SYSTEM ON MY FEZ TURBO I JUST CHANGED THE THERMO AND WATERBOTTLE LET ME KNOW CHEERS MATT :D
Straight882003
Postby ~ John Reid ~ on Sat Nov 04, 2006 2:35 pm
not 100% sure, but i would to get all water out of it, take off the bottom radiator hose and it should all come out.
~ John Reid ~
Postby Straight882003 on Sat Nov 04, 2006 3:22 pm
OK CHEERS MATE BUT I HAVE ALREADY FILLED IT BK UP SO ALL I NEED TO DO IS BLEED IT IS THERE ANOTHER WAY CUZ MY MATE SAID THEY ARE SELF BLEEDIN JUST RUN CAR WITH PRESSURE CAP OF IS THIS TRUE MATT :D
Straight882003
Postby Dazza on Sat Nov 04, 2006 4:20 pm
Start the car up and turn your heaters on to full heat, and full speed.
With the cap off, squeeze the top radiator hose every few seconds and you should notice air bubbles appearing. Then leave it for awhile and try again. This should help but always be aware of the coolent level, oh and dont put coolent in when the engine is hot, or you could crack the head.
Dazza
Postby Straight882003 on Sat Nov 04, 2006 5:44 pm
ur my hero mate cheers matt :D
Straight882003
Postby Straight882003 on Sat Nov 04, 2006 6:45 pm
hi mate still no joy the heatin is luke warm at just under the 'R' then the fan kicks in and goes cold again PLZ TELL ME ITS NOT THE HEAD GASGET cheer matt :(
Straight882003
Postby 285Andy on Sat Nov 04, 2006 7:12 pm
why would you think the head gaskets gone? did you have the same problem before you changed the a/freeze then?
285Andy
Your car: fiesta rs turbo
Postby Straight882003 on Sat Nov 04, 2006 10:35 pm
i have had the car for 2months and i have had no heatin i changed thermo and header tank and the heatin is luke warm now which it was never b4 but cuz i aint good with engines so i dont know what else it could be any ideas cheers matt :D
Straight882003
Postby 285Andy on Sun Nov 05, 2006 3:25 am
sounds more like a possible blocked heater matrix TBH or youd be bleeting about the water spouting out like a fountain or overheating at the first oppertunity or just generally fukked up lol :D
lets put it this way, if it dont overheat, there cant be much wrong lol :D
285Andy
Postby Straight882003 on Sun Nov 05, 2006 10:21 am
cheers mate but the car dose not over heat so if it is the heater matrix and its blocked will i need a new1 and how much are they cheers matt :D
Straight882003
