Water inside the car-side conductor
6 posts • Page 1 of 1
Good afternoon I have a problem with my car a fiesta mk3 1992 and the ground water enters the driver's side is full of water. Already pulled the carpet but I see no holes or anything. Any of you guys ever had this problem thanked a help from you thanks.
- nuno almeida
- Your car: XR2I 16V
Re: Water inside the car-side conductor
Yes, I have that problem now. I've discovered the windscreen isn't sealing properly so it's leaking a lot when it rains. All the rain water ends up in the front footwells
- Tweek
- Your car: VW Golf GTD
Common fault mate it seems poor design It runs Down either by ecu or fuse box the two worst places only ford hey
- rsturbonutter
- Your car: Fiesta RS turbo
windscreen rubber , heater matrix , or rusty wheel arches letting water in
- knuckles
- Your car: Fiesta Rs turbo
door seals also... i have water coming in through there
- AW0L
I'll have to check the rubber windscreen water concentrates any where near the center console has a lever of change. As to the door rubbers but I doubt I will see if the rubber doors water would be more concentrated near the door and I close the door the carpet is dry ....
- nuno almeida
