Water temp and oil temp gauges
3 posts • Page 1 of 1
Where do you plumb these into on the car? Not the gauges but the senders?
- IanRST
Hi mate,
The sendor for the water temp gauge can be put the same place as the ford one ( you will loose the ford one in the dash - but it don't matter if you have a better one )
This is located at the front of the head on the right of the exhaust manifold with a thin wire going to it.
For the oil temp gauge, Nomad racing do an adaptor for the sump plug that houses the sendor in the new sump plug. It still uses the nylon washer so it doesn't leak, and fits perfectly.
- MarkFRST
i have a brand new water temp gauge sendor fitting kit in my garage!
its to fit in the top hose...... keeps the origional ford gauge as well that way!
pm me an offer if your intersted mate!
- xrsi
- XR(ustyAtTheMo)SI
