Went &Got a Dyno Tune,had sme problems&need sme hlp
5 posts • Page 1 of 1
Went 2day and got a dyno tune and power read on my xr2i 8v
the power peaked at 117bhp!
- the car was missfiring abit when running lean( i had changed the spark plugs 2 weeks ago, a oil change, new fuel and oil filter, and pump aswell) ( cud it be the silcon leads or the coil pack?)
- my fse boost valve was playing up aswell?
he suggested to get the original 1 frm ford? i wz thinking buying a new one!
the power pulley has to be adjusted propley
he did a bit and made a slight improvernt
he also said to change the crank sensor!
what the hell is that! and what does it do!
can you guys help me out pls! i need som advice and direction from what 2 do!
cuz i want my car ready for the track event for next week! and least kicking 125bhp!
cheers! peeps!
cheers! peeps!
- Xr_Dub
Re: Went &Got a Dyno Tune,had sme problems&need sme
fordunit :Went 2day and got a dyno tune and power read on my xr2i 8v
doubt its the coil pack when they go its permanent misfires, use only ford original leads, the rest are crap, also make sure the plugs are gapped correctly and spray silicon grease inside the leads
yeah fse are ok, but can go wrong. standard ford unit is fully adjustable but any changes must be done in conjunction with rolling road set up
u on about vernier? needs to be done on rolling road
can cause misfires, if u change this u MUST buy the modified gold connector loom with this as standard loom has steel/zinc contacts and new cps is gold plated so mix the 2 and the 2 substances react and cause high resistance and misfires!, its above the started 2 pin connector goes into the block and reads flywheel position.
cheers! peeps!
- snake
- Trainee Burger Flipper
- Your car: ford
cheers snake!
Codey some of my mods
- kent cam kit
- vernier pulley
-new tappets
-skimmend head
-pistons kit oversized
-k&n
-boost valve
- scorpion ex
- kent cam kit
- vernier pulley
-new tappets
-skimmend head
-k&n
-boost valve
- scorpion ex
- Xr_Dub
