Wet and dry??
Wet and dry??
Postby Lpoynter18 on Sun Jun 09, 2013 8:51 pm
Hi there need to rub down my frst body kit what is the best thing to use? I have been told wet and dry but what gradient do I need to get? Any help will be very much appreciated :)
Lpoynter18
Your car: Mk3 fiesta "n" reg
Re: Wet and dry??
Postby mikeymikeyp on Sun Jun 09, 2013 10:07 pm
a couple bit of 600/800 should do u the 600 for the rougher bits
mikeymikeyp
Re: Wet and dry??
Postby RS EDDIE on Sun Jun 09, 2013 10:33 pm
800 is a good base for keying the surface for repaint, then down to 1000 grit used wet. Alot of bodyshops use 800 grade to key for repainting. It all depends on how the surface is that you are painting.
Imagine this..........Sanding a Pea with 40 grit and sanding a pea with 2000 grit or sanding a tiny raised bit of paint flake with 40 grit or 2000 grit!!! :D
RS EDDIE
Wet and dry??
Postby Lpoynter18 on Sun Jun 09, 2013 10:44 pm
Okk wicked will get some on order thanks for the help guys :)
Lpoynter18
