What are swirl pots and oil breathers?
4 posts • Page 1 of 1
What do they do for the car?
- IanRST
The oil separater does as the original but i bought 1 because the oil the orignal seperator spits into the engine bay when over filled or whatever now drains back into the sump.
Apparently the original sepator strugles when running higher boost.
The swirl pots seem like a gimic, not sure though.
- MIK3Y
The water swirl pot is meant to spin the water as it flows and gets rid of any bubbles which can cause an air trap in your coolant pipes....................but................... Ford already thought of that as your thermostat housing does it
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
