WHAT BRAKES AND WHAT WILL INEED
13 posts • Page 1 of 1
I own an 95 RS1800 and it has a set of 17s on it and i want bigger discs. can any 1 tell me aht the best ones are to fit and what i will need to make them fit?
- gavrs1800
im sure max wil help u regarding the cossie brakes....think they just need some spacers made up but im sure he will help u there....the st170 IIRC requires the hub machined to increase the holes slightly as the nuts for the calipers are slightly bigger then the fiesta ones....think its 12mm instead of 10mm
Wheres the experts when you need them
- Superal
- Location: Waltham Abbey, Essex Drives: Peugeot 206 Work Van
Id go for ST170 as you have 17's
Cossies just need spacers, Not sure on the bolts etc for ST170's. Will just need drilling maybe.
- Xr_Dub
- chumkila
- Dirty Post Whore!
Fitting the ST170's is easy, all you need to do is drill your hubs from 10mm to 12mm before fitting.
- chumkila
- Dirty Post Whore!
