what brakes for my frst
6 posts • Page 1 of 1
hiya again lads im sorry to keep asking all the questions but i want all your knowledge. as some of you might know from my other posts i am rebuilding my fiesta its running approx 200bhp and as all of you will know standard brakes are not the best.lol so i am just wanting to know what people are using cheaper options would be best as i have already spent a good 1k on it so far and still need bodywork sorting and new wheels as i hae the standard 14" wheels on. all comments appreciated thanks again for those who have posted in my other threads it all helps
- andyb-rst
Re: what brakes for my frst
without fitting 15" wheels there arent many beefer calipers u can fit
honestly mondeo 2.5 v6 calipers which they fitted to the st24 have more than enough bite
same as the cossy 4x4 but cheaper
if u then get a set of dics and pads lookign at £120 for discs and pads and £80 for calipers at scrapyard and ull have more than enough bite the scrappy i currently work for might do the calipers for a bit less give em a bell and ask 07918731148
- HCS PIMP
spot on mate cheers i would really like to keep the brakes to a ford setup as i want to keep the car as original as possible so i will defo keep them in mind cheers as i need bigger wheels before i can go 4 bigger brakes
- andyb-rst
ST150 brakes go straight on and you can pick them up for about £100, they fit under a minimum of 15" wheels
- M1K3Y_B
Car: 1996 Ford Fiesta Classic
Alright mate, if your just using the car on the road and want to keep the standard/small wheels I'd go for a set of brembo max discs (often listed as being for a mazda 121) and either ferrodo DS2500 pads or mintex 1144's with goodridge braided lines.
The mintex have better cold bite but the ferrodo's just keep getting better and better the harder you push them but need a couple of brake applications to get them up to a decent temperature.
This is the set up I have at present and it will give you plenty of bite for road use but will fade if you intend to go on track.
- Makaveli
black diamond drilled and grooved discs + pads, think I paid £130 and fit under the 14" 3-spokes.
- Rusey
