what break oil do you use?
7 posts • Page 1 of 1
I changed mine to 5.1 oil. And it's alot better on the pedals.
- ivannemec
I use a good quality dot 4 on the escort and fiesta as there less likely to absorb moisture and on the cossie i use castrol srf.
3dr Sierra Cosworth Track car
S1 Escort RS Turbo
- wildheart
When i was building my FRST i thought i'd get brand new brake (disc's, pads and fluid) i got a good bargin from sonny @ ESP design. he recomended to go with EBC all round.
The brake are smoother and sharper than the standard stuff.
Reall happy with it
Reall happy with it
- RSTsteve
just be careful - 5.1 is a better brake fluid and can handle higher temps, but it is designed for race cars where the fluid would be changed all the time (sometimes for every race). it will not last as long as dot 4 and should be regularily renewed
- FezV6
I use Dot-4 on track and have no issues with it despite being a bit of a hooligan (apparently).
Problem with brake fluid is most people don't realise it absorbs moisture from the air (hygrascopic I beleive is the term but await correction) and as such should be changed every 2 years
i got some dot5.1 for my rs but after thinking about it i decided to stick with dot4, as said above, its good, but needs to be changed.
better off sticking to dot4 tbh
