what cluch is best for my fezz
5 posts • Page 1 of 1
hi iv just put a 2.0 zetec with a 1.6 box in my fez but i dont think my cluch is likeing it wen i floor it off the lights (as you do) there was no wheel spin just that horrible smel of cluch needles to say ive not done it since dose any one no what cluch will put up with the power untill iv saved enoth for a after market one thanks
- fezzziboy
Re: what cluch is best for my fezz
Standard clutch should be fine.
- fiend
Had the same problem with mine they dont seem to like the hard launches .
You could try fitting a new clutch kit (plates/release bairing i got 1 for a rs turbo and it was fine.
Try to get a one from a ford dealer as i have notices the relase bairing work a little better.
Replace the clutch cable and that will give it a better feel and faster responce as the standard fiesta clutch cables arnt the best and should be regularly cheacked along with the clutch pedal hight which you should give a check.
The clutch pedal should be just higher than the brake peadle as if its not set right it could be wot is causing the clutch to burn straight away under power.
You could try a better gearbox it would help put the power down a bit better as my 1.6 box didnt last long on hard launches mabe a rs1800 or rs turbo gear box (with the lsd) ither can be picked up at a resonable price.
- THEHOG~
wud the rs turbo cluch go on the escort 1.6 flywheel if not what is a good cluch for a p reg escort flywheel as that is what is on it he forgot to mention
- antn0585
Yes they all have a 220mm clutch.
- allinking
