What comp. ratio on rs1800 supercharged engine?
18 posts • Page 1 of 1
What compression ratio do you recomendet for 15psi of boost and 75hp of nitrous on RS1800 engine.
Engine will be run with supercharger and nitrous.
I think that 9:1 will be fine with forged pistons and properly ignition setup?
Or do you thing that 8.5:1 will be best.
- hemingway
I was going to say 7.5:1. You could possibly manage 8:1 with good mapping and fuel? Maybe others have input? I'm on 7.8:1 with 12psi and the mappers were a touch concerned about det occurring.
What is it with Fords and such low compression? Many japanese engines run higher compression without problems (even on our lower octane fuel).heeman10 :I'm on 7.8:1 with 12psi and the mappers were a touch concerned about det occurring.
- sailorbob
sailorbob :What is it with Fords and such low compression? Many japanese engines run higher compression without problems (even on our lower octane fuel).heeman10 :I'm on 7.8:1 with 12psi and the mappers were a touch concerned about det occurring.
I was going to say the same thing. The Passat 1.8 T has 8.5:1 and it can run on 95 RON fuel so if Hemingway uses 8.5:1 with a good fuel he could be runing 1 bar without detonation risk.
Fahr nicht schneller als dein Schutzengel fliegen kann
- FedeArg
Re: What comp. ratio on rs1800 supercharged engine?
hemingway :What compression ratio do you recomendet for 15psi of boost and 75hp of nitrous on RS1800 engine.
what management are you running? you can run on 9:1 comp with loads of fuel and more retard. andy nicolls who owns an-racing on his rover 25 he is running a gt35r external gated turbo @ 45psi on standard compression 10:0:1 and 75 shot of nitrous, cost serious money the engine runs I beam steel rods he wants to be the first one in the country to do a 10s 1/4 fwd
the car geared for 200mph but he had a few problems @ totb so only done 177 so far the car achieved 0.60- 4.1 0-100-7.6 0.150-15.2
gt 2876r aka gt25/40r roller bearing turbo, L8 ecu, 850cc injectors mapped by msd to 12psi with LC & AL closed loop 30+ psi soon
0-100 10.84 100-150 9.24 154mph daddy thrash 06
- turboboss
Excursion :Zetec heads don't like high compression, apparantly...
care to elaborate on why they dont mark, is there a common failure on them you know about?
- FezzR
- God Damn Lazy
I dont understand that "care to elaborate?"
ZEtec head is not reason why comp ratio must be lower than 10:1 like original does. It is about knocking problem.
Ahhhh you dont help me much.... but thanks anyway.
- hemingway
hemingway :I dont understand that "care to elaborate?"
edit my post to hopefully make more sense,
- FezzR
- God Damn Lazy
The chamber design and squish area is the main reason the engine doesn't like high compression. The onset of knock is directly linked to these. I can't elaborate anymore than this as I don't have first hand experience of it going wrong with a high compression zetec turbo, but I fully trust the source of this info! Having you said that you intend to run 100 octane race fuel, I have no experience at all of how a Zetec behanves with that and I doubt anyone else here does.
In response to your original question, I would stay at 8.5:1. There really is little gain going for a high compression Zetec turbo engine, the real world gains are small.
hi!
my cossi has a cr of 8:1.
and i can run 25psi without any problems,
whats the reasen that zetec turbo use so less cr?
perhaps you need a good map with a knock sensor?
to run like hondas with 10:1 and 15psi?
the focus rs is near the same as the old zetec,
and you can run 20psi with the stock engine.
i couldn´t believe that the head is the weak point,
but perhaps someone can clear me up!
thanks alti
thanks alti
- alti
