What do we think of skimming?
20 posts • Page 1 of 1
Probably got to take the head off my new engine so what does everyone reckon to getting it skimmed / polished at the same time? I know increasing the compression is a bit dodge, but I reckon it ashould be ok if its only done a little and a nice little power increase as well
The engines an rs 1800 if that helps?
Cheers.
Cheers.
- Robz_Fester
i reckon go for it as long as u stay within tolerances. my cousin has an xr2 with a stage 3 head which he has just given to vulcan engineering to get skimmed...vulcan reckon a 5bhp increase!!!! if thats the score...im all for it!
bassboy
bassboy
- bassboy
- Authorised Trader
- 285Andy
- Your car: fiesta rs turbo
wont make a difference dood
skiming is only an issue with turbo charged engines.
A N/A engine has to have a high compression ratio in order to actively suck the air into an engine.
Whereas on a turbo lump its forced in thus the lower compression !
you will only need headskimmed if its overheated and or been warped !
also headwork on a zetec has to be very specific as the valves can f**k up on overlap.
not really that much point as you havent got more air going into the engine and so not got more coming out !
for the money it will cost very little to no gain is to be had !
- MadcatCraig
- BANNED SELLER
Craig, what you just posted was a load of cr@p
having his head skimmed will give a good benefit, just be careful on the stock ECU, dont go too far.
Skimming a zetec head wont cause any problems, generally speaking unless a belt breaks on an 1800 there is rarely contact, you can go about 5 teeth out either way before anything bad happens.
rs125 :MadcatCraig :
WTF does that mean lol
Ive just had a think about what you mean by this and i THINK i have figured it out?
Thing is you don't nead more air going in to get more power as you have raised the compresion so the air (same amount as before) and fuel get compresed more which creates a bigger bang which = more power ..
Obviously if you can get more air / fuel in that would give you more power also - thats why you have the head polished and ported ..
eg - if you had two identical engines (apart from compresion ratio)
one engine has a c/r of 11:1
one engine has a c/r of 11.5:1
If the same amount of air and fuel was going into each engine the one with the higher compresion would make the most power .
- rs125
Mark if you read robs original post !
i was refering to the comment about the head being skimmed being a bit dodge, as it can be on turbo engines.
I also said that the higher the compression on a N/A engine can benefit by drawing more air in !
RS125 what i mean is
if more air goes into the cylinders more gas has to come out thats where increasing the valve size can help.
Mark if you think what i say is a load of crap then thats what i was told by the guy who sorted my CVH and zetec head out !
- MadcatCraig
- BANNED SELLER
if you gonna take the head off anyway it'll cost ya approximatly 30-50 quid to have it skimmed. not mojor money. i would say it might be worth investing in vernier cam pulleys to get the best timing outa it though as it will be altered after
forgot, maybe the cam pulleys are non woodruff keyway anyway (like the later zetecs) in which case, forget the pulleys
- 285Andy
Craig I do think it's a load of crap - raising compression is a good way of achieving more power
Andy - yeah no need for verniers on zetecs they are not woodruffed!
Wikkid.
I reckon I'll go for it then. How much does anyone suggest having it done? I've never really looked into this before so have got no idea whatsoever Rather have you guys tell me than some dumb ass mechanic trying to get me money
- Robz_Fester
Speak to either Magnum Engines or D&R James. There on the Nuffield Industrial Estate. Highly recommend them, Magnum did my head and James are currently doing the block, pistons and crank.
Coming soon!!!!
- icecool
Put it this way a guy I know has a racing car thats an xr2i in there class they are allowed to skim to correct tollerances, lets say he has donea few headgaskets and it has been severely skimmed - On a STANDARD engine it made 104bhp @ wheels with just rasied compression and better injectors.
Skimming on N/A is VERY much worth doing...my new engine has had 80 thou taken off the block to raise it to 11:1 compression ratio and the difference is very noticeable as everything is instant, it basically means a better burn so you get a bigger bang.
therefore other mods aside its worth doing regardless of what air and fuel you have in and out, that can only add to it
- PF Dave
What do you reckon I can expect out of:
RS 1800 engine running 11:1
Decat pipe
K&N panel
Full powerflow exhaust?
Look slik eI will be doing it Gotta wait for funds though Christmas
Decat pipe
K&N panel
- Robz_Fester
If the head warps after head gasket failure for example you would have to or bin the head, of if you buy second hand and want to make sure its within tollerances.
I suggest as I am, and take it off the block in any case though!
- PF Dave
My only concern would be how the management might react to having the CR changed - Mark and Snake mentioned not going too far on the stock ECU and I think it's probably best to err on the side of caution.
A light skim will definitely make it feel a load better.
I think Craig's been smoking instant gasket again
- Project
- fiftyoneCL
