What handbrake
What handbrake
Postby KINGHORN on Fri Feb 15, 2013 3:02 pm
Ok a little confused now.
I have
ZS rear beam.
Mk1 focus rear discs.
Puma racing handbrake cable
Do I need to change the handbrake lever and short section of cable also as I will lose the undercar adjustment? If so what item should I get?
Also as the mk3 points for the handbrake cable are offset to I need to do something about this to even them up?
turbo restoration in progress
painted, interior half in, windows in let the rebuild continue
http://www.fiestaturbo.com/forums/post1715280/#p1715280
http://www.kinghorn1.wordpress.com
KINGHORN
Re: What handbrake
Postby mikeymikeyp on Fri Feb 15, 2013 7:15 pm
would you not be better using a rs 2000 cable ,im sure thats what folks use
mikeymikeyp
Re: What handbrake
Postby andymac on Sat Feb 16, 2013 12:37 pm
mikeymikeyp :would you not be better using a rs 2000 cable ,im sure thats what folks use
And it's what's suggested on fiestaguides :)
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
What handbrake
Postby KINGHORN on Mon Feb 18, 2013 7:04 pm
I'm confused. I got told to use the puma one !!!
KINGHORN
Re: What handbrake
Postby mikeymikeyp on Mon Feb 18, 2013 7:54 pm
well kick the guy in the baws :lol: :lol: :lol: :lol:
I just heard thats what is used iv not done the rear disk thing cos the drums sound so good "boom boom" :wink:
mikeymikeyp
Re: What handbrake
Postby AW0L on Tue Feb 19, 2013 11:21 am
puma cable is too long... i was also told this, i ended up making one from a focus cable, keeping the offset bracket, route the cables as normal (i started caliper end), cut the caliper crimp off, measure where the cable gets to the offset bracket and cut to length (remove inner cable first) once to length fit inner cable back in using mk5 hb lever to connect the 2 cables. at caliper end you will see the free ended inner cable is quite away past the caliper, here you will need to contact speedy cables (http://www.speedycables.com) and ask for the correct caliper fittings (P36). then again more measuring to get the cable length correct, this is very important to get correct, otherwise one side will work and other may not fully hold. once measured and cut, send to speedy cables and get then to crimp the ends on. its a hard job and i hated every step of it
or use the fiesta guides method and put the spacer inline, and retain the standard hb lever
AW0L
Re: What handbrake
Postby martin xr2L on Tue Feb 19, 2013 6:55 pm
I have rs2000 discs on rear with the RS2000 cable it works a treat but I did weld up a new bracket so the cable would go tighter this doesn't have to be done but as I had the car in the air at the garage I done it anyway! Go rs2000!
martin xr2L
Your car: fiesta xr2i
What handbrake
Postby KINGHORN on Wed Feb 20, 2013 6:31 pm
Yeah I'm thinking adapting the offset plate would be a good shout. Then I wouldn't need to adapt it and a new mk5 fiesta lever should work
KINGHORN
