what hoses are required
10 posts • Page 1 of 1
Am going from cvh turbo to zetec turbo in the next coming weeks am wondering what hoses will I need. Do I just need a zetec coolant hose set? Will be using my cvh inlet for the time being until I've saved enough for crazycages inlet and exhaust manifolds. The turbo will still be in roughly the same position I should imagine so am thinking I just need the coolant hoses. Can anyone confirm this. Thanks
- rsturbonutter
- Your car: Fiesta RS turbo
Re: what hoses are required
Not kidding you here, but i have the hoses to do so. I ordered them for my fiesta rs turbo when i was going to zt. And now im not. So i have the bottom rad hose thats pretty much a standard cvh one. But where the water pump is, the pipe is larger as the zetec pump is larger. I also have the top hose which is really just an rs1800 silicone hose
Ps. They are both Roose Motorsport
- Maxwell
- Your car: FRST - 2wd SAFF COS
So the rad to thermo is the same fella is it? What colour are the hoses you have mate am looking for blue ideally to match the rest
- rsturbonutter
Mine are black mate!!
- Maxwell
im on the verge of stripping my zetec turbo powered fiesta rs turbo so will have the rouse motorsport hoses for sale, just waiting on a deposit for shell........
so will also have all the conversion bits you would need if you do the conversion
pm me if your interested in anything
- Rsmark86
- Your car: Fiesta rst zetec turbo
you will need
1.8 sump and pick up
alternator set up
coolant hose set
i also have a zetec inlet modified for top feed injectors with modified charge carrier on mine with aftermarket fuel reg, so no need for adaptor plates
and a engine for sale
alternator set up
coolant hose set
- Rsmark86
Will take the hoses and conversion parts if the hoses are blue
- rsturbonutter
yes mate they are.........
ok will let you know if the guy gives a deposit for the shell
- Rsmark86
Cheers fella
- rsturbonutter
Pm sent mate
- Rsmark86
