what injectors and clutch
4 posts • Page 1 of 1
im buyin a fiesta turbo from my mate
the cars currently havin a low comp 1600 cvh built
i was planning to buy some bits and givin em to him so he can have them all fitted b4 i hand over the reddies
the spec is low comp 1600 cvh, 285 t2, stg2 t3, ahmed bayjoo chip(not sure on spec of chip??), pace frontmount intercooler,
also does the s2 lsd box bolt straight in???
thanks in advance
thanks in advance
- bigmatt_s2rst
you should run what ever injector the chip is set up for, but having low comp and all the rest id be wanting a custom map once the engine is built and run in.
Helix clutch seems to be flavour of the month
id be very concerned about running a pace intercooler with a low comp and T3
- FezzR
- God Damn Lazy
The gearbox bolts straight on, yep.
Find out the spec of the chip, and buy the correct injectors, and run the correct amount of boost for the chip. Would be wise to take it somewhere where they can check it's fuelling properly once you've fitted it all and run it in.
The pace front mount intercooler should be okayish, it's better than the double capacity intercooler at least..assuming that's not what you have!
