what power increase to expect
7 posts • Page 1 of 1
just bought a new head for my frst,just wondered what the typical power gains are? engine spec:
ported/polished head 43mm inlet valves
cossie spec t3 turbo
lightened/balanced bottom end and flywheel
stage 1 chip running 11psi
standard cam
pace intercooler/pace rad
accralite low comp pistons
thanks
standard cam
thanks
my old frst: 185bhp @11psi stage 1
my new frst: unknown...
- turbodaily
Re: what power increase to expect
turbodaily :just bought a new head for my frst,just wondered what the typical power gains are? engine spec:
standard cam
thanks
up the boost to 1 bar should see 200 but change the intercooler before summer pace coolers cant get the act down to a safe level
gt 2876r aka gt25/40r roller bearing turbo, L8 ecu, 850cc injectors mapped by msd to 12psi with LC & AL closed loop 30+ psi soon
0-100 10.84 100-150 9.24 154mph daddy thrash 06
- turboboss
im running 185bhp on 11psi at the mo hoping to get another 10bhp without turning the boost up.. intercooler is next on the list,thinking of getting a pro alloy front mount
ive never fitted an uprated head to a turbo engine before so im not sure what to expect,but i have fitted them to n/a cars ive had and they made a loada difference so hoping itl do the same
- turbodaily
All depends who's done the work and what work has been done, the head i got had the works done to it with a kent kit in it and i saw an increase of 27 bhp from 122 bhp to 149bhp on a standard unchipped engine but at that time the cam had worn when it was roaded, now its fitted with a new kent cam kit and feels loads pokier i'd say maybe 20ish bhp with a decent cam kit.
- Brammer
- Your car: Sierra Cosworth
i tried using a standard cam for abit and much prefer it over the cvh35 and piper t2, they just seemed to make it more laggy and move the power to top end. so im ganna stick to standard cam,as suggested by a few tuning companys
what size inlet valves do they use standard?
- turbodaily
The CVH responds very well to big inlet valves.
Puma Racing make there own valves they offer 43.5mm and 45mm inlets in addition to the standard 42mm heads.
Other "big valves" available are only 42.6 or 43mm. Hardly worth fitting which is why they make there own. The best heads to use for 45mm valves are the XR2i which is the same as the RS turbo as far as im aware ones from 1989 onwards, casting number 89SM6090
- NeoMagic
NeoMagic :The CVH responds very well to big inlet valves.
am am currently using a pumaracing 45mm valve head with there custom double valve spring system the head is worth 45bhp over most stage three heads... well i gain 50bhp on with the same spec just by changing the head cost me £850
- turboboss
