what rear disk set up
10 posts • Page 1 of 1
ok i no you proberly thinking oh not another post about rear disks.
anyway question is what rear disks should i go for to compliment my willwood 4 pots up front, want summin quite big and meaty looking.
also will a escort master cyliner be up to the job of 4 post and rear disks, if not what could i take one from
turbo restoration in progress
painted, interior half in, windows in let the rebuild continue
http://www.fiestaturbo.com/forums/post1715280/#p1715280
http://www.kinghorn1.wordpress.com
- KINGHORN
Re: what rear disk set up
oh and the load thing on the read beam can i remove that
- KINGHORN
mk5 rear beam with focus disk setup, yes the escort servo will be up to the job as not alot of breaking is done at the rear anyways, however if the front and rear are matched then the overall effectiveness of the breaking system is greatly increased.
- xrsi
- XR(ustyAtTheMo)SI
right i have rs2000 calipers discs and pads coming, got a escort master cylinder at the local breakers for a fiver
just need the carriers now i think, oh and a hand brake cable is that right,
zetec s rear beam the best to go for?
- KINGHORN
no not with rs2k items as they simply wont bolt up to a mk5 beam hence why i said a mk5 beam and also focus rear disk setup as the stub axle mounting bolt pattern is the same on the focus and the mk5 fiesta.
If i were you i would sell on the rs2k stuff and try and get focus ones, the handbrake isnt quite as good as it is actuated by the caliper not drums inside the disk, but its a better design i feel with everything being on one set of pads rather than needing shoes and pads.
- xrsi
- XR(ustyAtTheMo)SI
ah bolox, rite off to purchase some other stuff then
- KINGHORN
is a 1999 puma rear beam the same as the zetec s??
- KINGHORN
no the puma and mk4 fiesta had a fork type mounting on the rear shocks rather than the normal type that is found on the back end of the mk3, the later mk5 reverted back to this type so it will have to be off a later car for it to fit the mk3.
- xrsi
- XR(ustyAtTheMo)SI
so a 2002.
got informed from a mate last night that the 1.25 zetecs have the same rear beam?
- KINGHORN
The 99 puma rear beam should be eye mount as they changed it in 98 from the fork mounts, just check by looking under it. I think the zetec-s beam was a bit stiffer compared to the lesser models and had bigger drums but that won't matter.
- Adam31
