what size do i drill the holes in flywheel to
4 posts • Page 1 of 1
i was told i can use the efi flywheel from the xr2i cvh engine on the zetec engine .i was also told i would need to drill the flywheel holes for the bolts to 11mm how true is this ?after making the holes wider to 11mm is then a straight fit to the zetec engine?any info would be valuable to me want to get car on the rd rather than just talking about it.
- MK4 Rick
- Your car: Mk5 Fiesta
Re: what size do i drill the holes in flywheel to
turbonetic :i was told i can use the efi flywheel from the xr2i cvh engine on the zetec engine .i was also told i would need to drill the flywheel holes for the bolts to 11mm how true is this ?after making the holes wider to 11mm is then a straight fit to the zetec engine?any info would be valuable to me want to get car on the rd rather than just talking about it.
yes enlarge to 11mm
gt 2876r aka gt25/40r roller bearing turbo, L8 ecu, 850cc injectors mapped by msd to 12psi with LC & AL closed loop 30+ psi soon
0-100 10.84 100-150 9.24 154mph daddy thrash 06
- turboboss
Re: flywheel
turbonetic :when i refit the flywheel to the zetec what do i torque the nuts up to mate and should i use any loctite
yes use loctite i did'nt use a torque wrench just done them up with an air tool, i dont know what the torque setting are..
- turboboss
